Soldering to Ribbon Cable
  • Soldering to Ribbon Cable
    I have some flat transparent ribbon cable with copper lines between clear plastic. I need to solder wires to the cable. How do I do this? Can I just solder through the plastic?
    Thanks.
    No, you can't solder through the plastic.
    You need to seperate the wires, strip the ends bare and solder each one individually.
    How about the Wiki?
      What I mean is the flat clear stuff, I think its called flex cable (The stuff used to connect lcd to controller board). Not the computer stuff used for IDE. Do I need to scrape the clear coating off?
        That clear coating is insulation. You need to clean it off to solder to the wires underneath. It doesn't matter whether it's flex cable or an IDE cable or what.
        How about the Wiki?
          hrmmm- that's just a basic piece of knowledge that you should have before ever considering a project like this.
          If you don't know that virtually all wires have a protective covering, and that in order to solder to the wire you have to remove that covering, then I would suggest learning a bit more about electricity first.
          Jan Bennett
            http://www.mediacollege.com/misc/solder/index.html
            Jan Bennett
              strip the coating off. tin the wires. hold the wires together. heat them up together and bam!!!! dont forget to use "electrical" tapeafter you do this.
              practice on wires that you can throw away until you feel comfortable soldering. and get yourself an actual solder iron. that coldheat iron you see on tv is just a piece of crap.
              MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
              M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
              7" Lilliput 619 | WinTV | WIFI | Bluetooth
              Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
              Roadrunner | LSXvoid | IGuidance 3
              My Worklog
                amen.
                  I do actually have several years of electrical experience. However, I've never come across wires like this before. It all been PCB work and hookup wire until now.
                  Yeah, I guessed I needed to scrape the insulation off first. But back in high school we had some cool spray coating that you can solder through. I was just checking to see if this clear plastic may have been similar. Otherwise I would have been wasting my time scraping.
                  Thanks for all the help. Will try it out today.
                    good luck!
                    Jan Bennett
                      Done and done!
                      Used sandpaper to rub off the plastic. This doubled as a priming for the copper tracks. A one second touch with the iron and the solder went on the track and only on the track.
                      Wires joined like a dream.
                        congrats!
                        Jan Bennett
                          That's really handy info...lots of people on the forum will likely benefit from your positive experience and results...I know I was always afraid to try soldering to ribbon cable!
                          An amateur built the Ark. The Titanic was built by professionals.
                            I know this thread is over a year old but I would appreciate it if anybody could help...I ran into a similar problem last night looking over my Tveiw indash mobile video system..taking the screen off I snapped the ribbon cable connected to the screen board which provides power to just about everything (tv, aux, etc.) What I'm wondering is if can sandpaper off the ribbon and solder each connection individually (in which case what grade sandpaper should i use) or is this thing headed for a future in spare parts. It's not the best quality, the reason I opened it up was to fix a malfunctioned button but it works and don't want my money to blow up in smoke so fast
                            sorry camera phone pic, lost usb cable for camera but that's another problem.
                              I can't tell for sure from your picture, but it looks like the ribbon cable may have just be released from the connector...if so, open up the connector, slide the ribbon cable in and lock it shut. Otherwise I would look for a replacemnt cable. I don't think you'd be able to solder all those connections.
