Installing a speaker into a factory '97 sable
  • Installing a speaker into a factory '97 sable
    i looked in my car already and also in a wiring diagram and saw that there were only wires previously available to support my 4 factory set speakers. 2 front and 2 rear... if i were wanting to install a wicked awesome woofer i found would that require quite a bit of wiring and also investment into a amp? if not what's an alternative and if so what does the work that must be done mostly consist of?
    ~taco
    Have a look around this forum and you'll see that the core focus is on putting computers in vehicles.
    You'll get more information looking at a site that focuses on car audio, or maybe even one that's focused on Ford/Lincoln/Mercury vehicles or even Taurus/Sable.
    Good luck.
    How about the Wiki?
      but they used to sell tubes with amps built in. all you need is to take a signal from the rear speakers, and power ran from the front. not the best route to go(its better to use an amp and 2 speakers). good luck on your search. come back if you want to put a pc in your car later.
      MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
      M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
      7" Lilliput 619 | WinTV | WIFI | Bluetooth
      Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
      Roadrunner | LSXvoid | IGuidance 3
      My Worklog
        http://bazooka.com/productAutoAmplifiedBTsBT.asp
          http://www.the12volt.com/installbay/vehicles.asp
          I dont know what year your cars are so I'll have to let you do some research. This also includes alarms as well.
          I created a generic user name for that forum that anyone on here can use as well.
          Username: g20.net
          Password: geedub
          (Yes this was originally posted on the g20.net forums)
