Motoputer/Mobile DV Capture
  • Motoputer/Mobile DV Capture
    Hi,
    Although I'm new to this site I've been reading the most that I can of it. Great source of info!
    I'm a one-man-band video producer and ride a Honda CBF600SA.
    My idea is to build a motoputer that can double as a Mobile Video Capture Device when doing video jobs.
    My question here is: what kind of specs do I need to do it? preferably on the low cost side.
    I'll use it for:
    Video:
    - DV Capture with Serious Magic's DV Rack (great software)
    - reviewing footage shot on tape or direct to disk
    - some sort of teleprompter for broadcast like jobs
    - very very short and simple video editing on-the-fly
    - maybe on-the-fly dvd burning with an external usb dvd-rw for an impacient client
    - webcasting live events
    Motoputer:
    - GPS
    - webcam installed in front and rear (video recording)
    - voip calling
    - gsm calling
    - mp3 and radio listening through earset (no speakers)
    - fuel consumption (trying to figure this one out since its a carb model)
    Can anyone with an EPIA M1000 or anything lowcost try the DV Rack software just to see if it works?
    Any sugestions for this?
    Thanks in advance
    Paulo
    p.s.: I know that bikes are dangerous enough without a puter in it already. i'm a conscious rider. this is just something i really want to try.
    Bike - 2005 Honda CBF600SA - 100%
    Laptop - Compaq Presario 2516EA - 100%
    Laptop in Bike's Topcase - 0%
    Planning - 20% ?
    when i get to think of it maybe this thread is in the wrong section...sorry about that.
    maybe some moderator can move it for me?
    thanks
    Planning - 20% ?
      It's not in the wrong section.
      Nobody with an EPIA board who's willing to experiment for you has responded or been able to respond.
      Considering the specs of the software require a minimum of a 1.,4Ghz processor and a 3D card with at least 32MB RAM, I'd say an EPIA board is a poor choice for runing DVRack like you want and possibly wouldn't even work.
      The HDV option requires even more computing horsepower.
      How about the Wiki?
        thanks darquepervert.
        i was getting a little worried about screwing up my very first post .
        About Dv Rack...thats a great software...but i'm already looking for lighter options...found windv developed back in 2003...it's very simple but does what is needed. i'm waiting for a reply from the developer about the minimum requirements for that.
        another option would be to go higher on the specs of my setup...again: any suggestions? keeping on the low cost side of things?
        thanks
        Paulo
        Planning - 20% ?
          There's lots of options.
          You could use a newer laptop that has the specs needed for your DVRack software.
          The low-power versions of the Turion CPUs are a good choice, as are mobile versions of the P4. You'd still need a decent 3D accelerator card, which hogs more power.
          The power is the main issue here, really. If you plan a system right, you could power it with the DSATX DC-DC PSU or an inverter, if you choose to go that route.
          Keeping it low-cost is going to be the tough part, though.
          How about the Wiki?
            Maybe i'm just overthinking it.
            I have a compaq presario laptop that fits neatly in my top-case (old non-centrino P4 2.5Ghz).
            Is it ok to use an inverter in a motorcycle? I know that bike's electrics tend to be quite picky...besides their small bateries.
            This way the only thing that stays on the bike are the wires and the "implanted?" webcams. I could still use a touchscreen monitor in the front of the bike from the vga-out in my laptop and gps and 3G pcmcia board for internet.
            I think its starting to make sense to me!
            Planning - 20% ?
              I don't think it's wise to power something so power hungry on your bike. Get a lower power PC and you might be better off.
              Jan Bennett
                The only problem with that is the lower-power PCs won't run the application he needs to run (or run it well, at least).
                It's definitely a conundrum...
                How about the Wiki?
                  I understand, but a bike doesn't have a big alternator (stator) on it.
                  1.4 gig you can get that in a mobile processor, the laptop he mentions is not a mobile processor....if he went with a mobile processor, I'd think it would work out better
                  Jan Bennett
                    Another concern I'd have is HD speed, on a bike you're going to need a lappy harddrive and I'm seriously doubting an IDE lappy HDD will do the trick. You may consider running the editing software from a lappyHDD but carrying a firewire external drive as well...
                    I agree with red in that the stator on a bike won't be able to handle an inverter for a power hungry PC. Since your consulting us, my opinion is buy a high end lappy with SATA harddrives and a fancy case to carry on your back while you take the PC to your clients.
                    Progress [I will seriously never be done!]
                    Via EPIA MII
                    512MB RAM
                    OEM GPS (embedded)
                    nLite WinXP pro on
                    1GB Extreme III CF card
                    Carnetix 1260 startup/ DC-DC regulator
                    Software: Still, re-Writing my existing front end in .Net
                      you can get laptop drives in 7200 RPM now...
                      Jan Bennett
                        I've been using this laptop to do the kind of things I want to do with this project. In fact, until 1 year ago it was my only PC and it handled video editing, capturing and after effect work. Slowly but steadily. So I know that it can take the task.
                        The power brick says on its back:
                        90W
                        Input: 100-240V~1.5A
                        Output: 19V 4.74A
                        It's an old P4 2.5Ghz and gets hot in the baseplate in the processor area. Nothing that cant be solved with usb fans or some venting holes in the topcase.
                        Is there a simple way to calculate the power needs from the given values?
                        will something like this http://www.powerstream.com/lta-Compaq.htm work?
                        Or is the limitation only in the bike's alternator?
                        FWIW...there are official honda handle warmers...dont know the wattage on that...but wouldnt they be more power demading than a laptop?
                        EDIT: red...the 7200RPM really increase the performance...but from my experience in working only with this laptop it can cope quite well with the 5Mb/s datarate required to capture DV via firewire. I already have an external firewire and USB2.0 enclosure with a 3.5"HDD that I used for heavy work in the laptop that I can use now if more recording space is needed
                        Planning - 20% ?
                          usually those heated grips are like 30 watts on the high setting.
                          Your computer probably pulls closer to 90watts if not more with that desktop processor, hard drive, screen, cd-rom, memory, video card, etc.
                          Find out what your stator can handle then we can go from there.
                          Jan Bennett
                            from my bike's english section manual:
                            Battery: 12V - 6Ah
                            Generator: 0.34kW/5000 rpm/min
                            Headlight: 55W(+55W max light - dont know the english word for it but not of general use)
                            brake light: 21W
                            Turn signal: 21W*4
                            Position Light(?): 5W*2
                            License light: 5W
                            So, from the lights only there is a constant 230W (if I drive like a blinking christmas tree and with the break permanently on - not likely to happen)
                            If I understand it right the generator can put 340W out. which leaves 110W for accessories. Is this right? how can I measure the generators output at engine's "idle mode" 1300rpm?
                            Planning - 20% ?
                              no real way
                              a multimeter cannot handle the amperage that would need to be run THROUGH it.
                              They make ammeters that test current, you'd have to see if it works on DC.
                              Jan Bennett
