how long will the carputer run on the car's battery?
  • how long will the carputer run on the car's battery?
    Just curious
    how long will the carputer run on the car's battery??
    I was thinking of add a security feature, but it will require the carputer to be on full time, not just sleep mode?
    I'm guessing 12-24 hrs???
    Depends on:
    1) How much power your computer draws.
    2) How much power your battery supplies.
    Provide those two numbers and you just answered your own question.
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
      using a laptop
      power supply output is 16V 4.5amps
      battery is 660cold cranking
        Well I suggest not trying to find out, unless you have a deep cycle battery.
        ODYSSEY
        Originally posted by Tidder
        Digital-Car UK|
        (\__/)
        (")_(")
          Get a second Deep Cycle battery and run it that way. Have the battery act like the wall plug in XP, so when the battery goes bye bye, then the laptop's battery kicks in for another 4hours kind of thing. When laptop battery is below 2%, then shutoff. You'll get a bit from that. I assume this is overnight security, so that should be sufficient.
          But if this is a camera thing, then more power. If you want wifi to upload it to your homepc so if they do steral your car, they don't take your proof too, more power. You get the idea.
          1.9in x 2.9in -- 47mm x 73mm
            is this to have a camera in your car, recording the goings on in, and out of the vehicle?
            thats what I intend on doing, plus the alarm, so the alarm will scare them away, but not till they've already been recorded
              if you don't want to get a second deep cycle battery, split charger, etc, you can get an M2-ATX which will provide you with ample 12v power (10A I think) and will also monitor the battery level to shut down if it goes under 11.2v (or some figure close to that). you also get 3.3v and 5v should you need it for anything else.
              of course a second batter is the most effective solution to your problem since it provides you redundancy/isolation for starting your engine, and gives you longer times of supply. It may be a little more costly however and may require a little more work to do.
              Current:
              [BMW E46 ///M3 Convertible]
              Previous:
              [BMW E31 850CSi]|[BMW E39 535i]|[BMW HVAC Research]|[IBUS Scrolling Text]|[BMPuter]|[Velocity]|[TomTom]|[Vision]|[Space Navigator Driver]|[Super Fast Boot]
                for computers, power draw is low.
                the voltage u say is 16v with a max output of 4.5A. That means at full tilt, you would be seeing a draw of 72w or on 12v battery equaling 6A.
                If considering getting a 2nd battery, do what is suggested, get a deep cycle, they are made to discharge for very long periods of time and be discharged FAR lower than a standard lead acid can.
                I would suggest getting an Isolator or Solenoid relay so the battery's charge does not share itself with the stock battery, the life expectancy will be lower if that happens.
                Next- to find a good battery, look at reserve time specs on batteries. These are low current discharges labeled by minutes before battery dies. However, most Reserve specs are done at 25A which is way higher than what u need.
                I would suggest to go here- http://www.lifelinebatteries.com/marinebatteries.php
                There batteries are very nice and if ordered direct through them, you should get em cheaper than buying from any of their retailers.
                Their GPL-4DL is considered a Group 4 battery able to do 8A of constant output at 1375 min straight. That's roughly 1 full day as 1440 min equals one day.
                Group 4 batteries are roughly around $300 through this company i believe but there is one option for a battery and how to find which battery to get.
                  I killed a Champion Heavy duty battery perminantly with my carpc by leaving it on by accident overnight. Killed the battery hard.. Wouldn't hold charge the next day and this was a brand new battery about 3 weeks old.
                  I've been searching for a voltage cutoff ciruit or maybe some software for windows that will detect the voltage that the power supply is drawing and if it falls below a certain voltage from the battery it will cut off the computer or shut it down in a timely mannor instead of just cutting voltage to the pc all together.
                  CAR INFO HERE
                  "He who dies with the most toys, wins".
                    Also have a look at Optima batteries. I have a red top as main and a deep charge yellow top for all the goodies. Will test later this week how long my car pc will last.
                      well, im not saying this is good... but in my car, I had set opus 120 on taxi mode (never power off) because I was running deliveries since our driver gave up and quit...Anyway, once I got home, shut the car off, but forgot about the pc and opus on taxi-mode since my screen hides away upon ignition outtage.
                      Basicly my pc was left on and GPS on as well for ~18 hours before i returned to the car. The car started up fine. As far as im aware, its not a special battery... just what ever came with the car. I was surprized it was not dead. Anymore, im not afraid to leave the machine on. But I avoid doing so unless work conditions call for it.
                      *thinking*....what a wonderfull idea. setting up a cam inside the car to record any motion triggered activity to a hidden hard drive... I like the idea. Hmmm.... "Asus video security" software would capture motion activated. then its just a matter of positioning the cameras ... something like infrared assisted.... *goes back to the lab's drawing board*
                      ~0okami.Digital
                        with having motion sensors, you'd have to point them down, and even if you did, if someone walks by your car, it would start recording, which doesnt help at all
                        so you'd need a way for it to record say, 5 minutes, then stop if theres no more motion
                        then u dont have 5 hours of video to look through
                        no?
                          As far as where to put the camera.... create a custom mount hole in the rear view mirror facing the driver side window. that way its pretty well hidden (most are black, which is what the cameras are usually also so easy to desguise). only problem is if sum1 gets in to drive and changes it, you gotta reset the whole thing so scratch that idea lol
                            no?
                            In my mind when I toyed arourd this this idea I always figured I would use a aftermarket alarm as the trigger. Maybe even have it tied into a dual-stage shock sensor if you want and have it start the recording in one of the stages of of the sensor.
                            As a suggestion to the OP, I would highly suggest a dedicated deep cycle battery. Most people drive their cars daily but if you skip one day I can almost guarantee a dead battery. Even my new Optima yellow top , with the PC in hibernating with a couple (live) USB devices drops to around 8-9v after three days. Discharging a battery to zero volts (or very near) and it's pretty much dead for good - especially a non-deep cycle.
                            My Install Thread
                            digitaljetta.com
                            MKIV VW Jetta
                            How do I get sound to my car?
                              motion detection via software is the best mechanism I would say.
                              Current:
                              Previous:
