add wire to connector and circuit diagram question
  • add wire to connector and circuit diagram question
    finally i got some factory connector for my head unit but now i have to add few wire to the connector. i know i have to relesase the secondary lock in order to add wire to it. can someone tell me how to add wire to that connector?
    according to the pic below, anyone know what do they mean (the blue and red area)?
    Wire shielding is my guess. Omitting it allows the possibility of interfering signals, but I think you can probably be without it just fine.
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
      anyone want to tell me how to add wire to that conector?
        You want to add pins or just extend the cut wires? If your going to extend the wires, just get yourself some crimp connecters and extend them. Or solder wires and heat shrink or tape them.
          never tape wires, always heatshrink
          tape is unreliable, can lead to shorting, which obviously isnt good
            ehh, not so much. I've had plenty of heatshrink end up with holes in it over time. If you actually spend a couple bucks and buy the good electrical tape and apply it properly it works just fine. The key is smooth even tight layers so the tape can properly adhere to itself and the wire and form a bond.
              the glue on tape will come off eventually, it always does, then it gums up and its gross
              and heatshrink shouldnt get holes in it, unless its rubbing against something, which is never good, and wires should be secured anyway
                I want to add pins to the connector. but i dont know what kind of pins should i get
                  anyone know what kind of pins should i get for the connector?
                    When I attached my carpc to my stereo system, I just bought extra connectors and stole the pins from them. Do you need more pins? It looks like 12 pins in the pictures above. Did you need more than that?
                    ...it never ends
