Install pics
  • Install pics
    Front view
    anotha
    anotha
      LCD
      anotha
        Carputer
        anotha
          and the donor is
          last one
            Great install!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
            I like the way that you have your system setup.
            How much did that display cost you?
              nice car. hit ctrl+d to doublesize winamp. might improve visibility
              My cars
                Nice install! that would look even better if you had some neon shining over the carputer. what year Civic is that? Also, how did you make the IRMan eye so small??
                You can definately tell summer is here, so many people completing installs.
                2004 F-150
                Shuttle XPC, 80gig HD, Wireless Internet, DVD
                "How piMP3d is your ride??"
                  He probably just took the receiver out of the casing and extended it into the dash. and bah, bunch of wusses waiting for summer its no fun if you don't loose the feeling in your fingers from the cold. and better than that, doing it at night in the winter (as i did after work, considering i got the mp3car bug in november).
                  and a very nice setup, a via eden board im guessing?
                  -Nick
                  _____________________________
                  www.mp3vw.com
                    thanx
                    It's a 94 civic.
                    The mobo is a FV25 with a PIII 866,
                    a keypower DC-DC PSU 250 watts resides under the mobo.
                    The display cost me an arm and a leg because I bought it just
                    when this motorized displays were starting to come out.($1,200.00)
                    and I did what MP3DUB mentioned above.
                      alsmost done..
                      Eventually I'll finish it, I still have to find a nice custom place for
                      my removeable hard drive rack and cover the mobo with a nice sheet of plexiglass which I have to cut a hole on for the CPU fan to bring cool air in.
                        @ anothamp3frk
                        Hi i saw your pics - nice LCD !
                        I have a question . On the picture it seems that the image doesnt fit 100% of Screen ? Is this right ? I ahve the same problem - anyone with a solution ?
                        it 's winXp right ? I wanna use the same OS - could you tell me what resolution u use ? to get this kind of good image from desktop??
                        MAny Thanks
                        Felix
                        - please ecuse my poor english
                        =>> Carpc Version2 -- Epia M 10K based<<=
                        ::Epia M10k,7"VGA/40GB2.5",GPS,Opus90W ::
                        ::trying to build second low cost carpc::
                        ::Automp3.de :: CAR= Renault Clio2 - 2 seats 1.9D
                          settings
                          Yeah the fv25 board in windows XP will not use the whole lcd when the composite output is being used, still looking for a solution.
                          The resolution I'm using is 800*600, but also to make everything
                          more visible I made everything bigger in the appereance Tab in display settings.
                            My Svideo out (ATI) also doesn't fit my tft :-( will change to Geforce because that works fine with TVout ( Tvtool needed)
                            -I wanted to buy such a FV25 Board but if it does the same on svideo its no more interesting me -
                            Thanks 4 reply
                            Felix
                              Why not just use an external VGA 2 Video converter??
                              Im using the Trust encoder, that encodes the vga to video signal, the video signal can then be resized, moved around, just by the touch of a button on the converter
                              see trust.com for info
                              Regards
                              Richard Skarsten
                              NORWAY
                              "If A equals success, then the formula is: A=X+Y+Z. X is work. Y is play. Z is keep your mouth shut."
                              Albert Einstein
