Need Help Changing Songs with Iguidance up in RR
  • Need Help Changing Songs with Iguidance up in RR
    I've read through all the threads pertaining to ignative=true|false and all that stuff. I have mine set to true and everything works good, except for the map disappearing thing, but I can kinda live with that since all you do is touch the screen and it comes back. I can't find any information on how exactly to add a menu bar to the top or bottom of the Iguidance window in RR to change songs and stuff. If anyone has one and would show me where to get the file and where to place it, I would be VERY appreciative as this is the only thing holding my back from installing my CarPC in my New Audi A4.
    Also, what is this thing called "clipping region"? I've done searches and I can't find any good explanation of what it is or where to find it or what I need to do with it. I'm using the BMV2 for Audi skin and can't find any reference to it in it's folder.
    Thanks guys.
    2006 Audi A4 2.0TQ6MT
    Mods:
    APR 93 Tuned
    Stasis SS Coilovers
    OEM RS4 Rear Sway
    Votex Skirts\Front Spoilers
    Deval Rear Spoiler
    18" BBS CO
    CarPC:
    Dell Latitude D600
    Pentium M 2.00 GHz
    1.5 GB RAM
    Windows XP Pro
    R.R. Front End
    Xenarc 700 IDT
    you need to make an external_gps.skin file as well as modify the external_gps.jpg to look as you want.
    1.9in x 2.9in -- 47mm x 73mm
      Open the external_gps.skin file with notepad, and put a forward slash "/" in front of all the lines that start with a "c"
      Make this:
      Code:
      /, C, x, y, w, h
      C01,000,055,800,545
      into this:
      Code:
      /, C, x, y, w, h
      /C01,000,055,800,545
      That will get rid of the map disappearing thing.
      As for changing the skin, Check here and here.
      Yeah google!
        Make this:
        Code:
        /, C, x, y, w, h
        C01,000,055,800,545
        into this:
        Code:
        /, C, x, y, w, h
        That really gets rid of iG map disappearing when switching back to the screen? I thought it had to do with how IG draws the maps... I am interested in this more. Do you have a link where you found this?
          Thanks for your help guys, I will give that a shot.
          Mods:
          APR 93 Tuned
          Stasis SS Coilovers
          OEM RS4 Rear Sway
          Deval Rear Spoiler
          18" BBS CO
          CarPC:
          Dell Latitude D600
          Pentium M 2.00 GHz
          1.5 GB RAM
          Windows XP Pro
          R.R. Front End
          Xenarc 700 IDT
            http://www.mp3car.com/vbulletin/road...-behavior.html
            http://www.mp3car.com/vbulletin/gps/...t-working.html
            I don't know why it works, but it is what I needed to do.
            Yeah google!
              Ignative=true then you remove the clipping region...otherwise, not.
              My Work Thread:
              http://www.mp3car.com/vbulletin/showthread.php?t=72552
              Source switcher for Lill
              http://www.mp3car.com/vbulletin/show...d=1#post841007
                As for skin comment in stead of just forward slash "/", it should be forward slash and a comma as "/,"
                so instead of
                Code:
                /, C, x, y, w, h
                C01,000,055,800,545
                It should be
                Code:
                /, C, x, y, w, h
                /,C01,000,055,800,545
                You see the line above the clip code? /, C, X ....
                OP, look and try other skin as well.
                Y2K Accord Dell GX150
                EmoRebellion is a SCAMMER
