GPS for odometer reading
  • GPS for odometer reading
    anyone know a dashboard or other type of app that uses the GPS sensor to gather trip info and store the total (or what would be the odometer reading on a normal car)? Making a custom modern hot rod and need to have odometer info.
    thanks
    I beleive Driveline uses the gps for the trip data maybe clockwork could add away to save the total to an odometer. Driveline also has speedo on the main page if you want and now a full set of gauges on a separate page using obd2 data. Just a suggestion SNO
      Android, have a very naic app for that, "UIspeedometer". keeps odometer data, and works as speedometer as well.. to use it on pc you will have to download "bluestacks player" wich is an emulator for android apps! that is how i had done it on mine...
        Torque with a OBDII Bluetooth reader/sender works great
        Sent from my EVO using Tapatalk 2
        My Lenovo Install in my Ford Focus dash...
        My Video
          You can now have odometer in Driveline. Clockwork did some magic and added it to the stats page. You can match to your existing odometer numbers or start from 0000000 under settings page. SNO
            thanks all! i am finishing up the apps configuration and will have to try some of these out.
              will this iguidance do it as well?
