how to screen capture
  • how to screen capture
    i took the whole clarion p200 apart and mod to run on liliput screen
    want to show some pix but cannot take good clear screenshot maybe my camera or me need some input please
    by the way im a newbie
    sorry if this question been asked
    If english is not your native language, you can write the same in your native language below/above the english and some people can help you. I speak a few languages as others do on here.
    But to get a stable picture, you need a tripod. You screw the camera to the tripod and it makes it not shake. That way the light is not wavy and blurry.
    1.9in x 2.9in -- 47mm x 73mm
    Buy now in the Store
      Depending on how close to the object you might want to use macro but do not use zoom. macro feature is activated by the flower symbol.
      System always under construction
        thanks for your quick respond
        thanks both for your help this's the best that i can do without tripod
        and used Macro on my Sony erricsson K-800i cyber-shot camera phone
        i never stop learning i took the picture in VGA mode
        by the way i use the Clarion N.I.C.E P200 using composite video output
        and feed to Lili Screen look very sharp all text are crystal clear
        this stand alone GPS work quite well compare to some other i've tried
        4 million poi and very easy to use. i did try some other gps program on my car pc but doesn't like that much so i remove the Clarion cradle's cover and
        a home make video output then feed to the Lili via composite video in, it look awsome
