Dell Optiplex GX270 Front-Panel Pinout
  • Dell Optiplex GX270 Front-Panel Pinout
    I'm not sure if this belongs here but I'm using this computer without the case so I had to find out where the power switch was located on the mobo. After a bit of searching, I found a site with some of the pinouts listed.
    http://www.motherboardpoint.com/show...60&postcount=9
    I just finished figuring out how to do this, and I rang out a bunch more of the wiring than was previously posted.
    here's a diagram of the connector on the motherboard:
    33 31 29 27 25 23 21 19 17 15 13 11 9 7 5 3 1
    o o o o o o x o o o o o o o o o o
    o o o o o o o o o o o o o o o o o
    34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2
    The 34-pin ribbon cable runs to a small sub-board for the front panel, which includes a 16-pin(2x8) header which gets another ribbon cable that goes to the "sub-sub-baord" for the actual poanel light and switches.
    The table below shows the functions of the pins on the 34-pin connector, plus where they connect to on the 16-pin "sub-board" header.
    34-Pin function 16-Pin
    1 GND 3, 7, 15, 16
    2 ?
    3 ?
    4 ?
    5 ?
    6 ?
    7 ?
    8 ?
    9 GND
    10 ? 11
    11 GND
    12 ?
    13 ?
    14 GND
    15 ?
    16 GND
    17 ?
    18 ?
    19 GND
    20 Pwr Switch 2
    21 “KEY”
    22 HD LED 4
    23 PWR LED - 5
    24 ? 13
    25 GND
    26 ?
    27 PWR LED + 9
    28 ? 8
    29 GND
    30 GND
    31 ?
    32 GND
    33 ?
    34 ?
    I hope this saves somebody an houtr or 2.
    Andy
    2008.5 White MS3 Sport
    Cobb Shifter Weight | Cobb SRI | Cobb AP | Cobb Turbo Inlet
    HKS BOV(Recirc) | Defi Boost Gauge| TRZ Tranny Mount| F2 BSD | F2 Oil Baffle
    Last....... i spend 2 hours search this info on my mobo with multimeter and testing.
    Good info!
      It took me about that long to find it. I need to buy a multimeter.
        How is everyone powering theirs? What power supply?
        This is the last piece of the puzzle for me so I'd appreciate some input.
          Why not solder to where the switch goes into the MB?
            i had a m2-atx but it's not enough. im sending it back tomorrow to exchange for a ds-atx.
              because this way is easier and not as permanent as solder.
                I ended up ordering Carnetix 2140 last night.
                  Hi All,
                  Great Forum,
                  Just my input, I just built a carpc with the dell GX270 with the new M4-ATX 250 watt 12volt psu, hooked up to the front control inputs on the sub board using the info above all works great. Thanks for your great info.
                  All the best
                  psxnut
                    awesome, thank you for posting the pinout
                    Thank you for doing the work! I bought a case with a coa only and can now use that case to build a good pc.
                    I need to figure out how to mount a motherboard on the odd looking motherboard mounts.
                    .......sorry, but I love Windows XP Home Edition and Bill.......
