"0" on the LPT output when the PC is switching on. how? - closed
  • "0" on the LPT output when the PC is switching on. how? - closed
    Hello.
    I am EPIA-M10000 and using LPT port(I am using data points, point 2,3....).
    When I just switching on my PC on the LPT port appears "1", it remains there during windows loading ....
    For a second it sets to 0 (when the drivers are loading, during windows booting) and again back to 1.
    Is it possible somehow to have 0 on the lpt output when the PC is booting?
    Regards, Alexy
    would it be a problem if it had 0the whole time, except that 1 second? otherwise you could just invert the signal...
    Greetz
    Dj NRG
      Closed.
        I will tell you
        look you have to make 2 pins 4 switching and connect those 2 pins to IC
        so the IC is like :
        pin 1 = 1 and pin 2 = 1 then out put = 0
        pin 1 = 0 and pin 2 = 0 then out put = 0
        pin 1 = 1 and pin 2 = 0 then out put = 1
        pin 1 = 0and pin 2 = 1 then out put = 1
        so when the car starts all pins should be 1 or 0 and the outout of the IC will be 0
        when the windows start , you have to make a startup exe to do send
        or
        after that it will wooooooooooork
        the IC number is : 4030
        good luck
        [email protected]
          sounds good
