3 Way Valet Switch Diagram - Transister Needed?
  • 3 Way Valet Switch Diagram - Transister Needed?
    Hey guys/girls
    In the process of setting up a valet switch, which is fine and dandy but I'm confused on one part.
    I want to have my computer power up when I unlock the doors with my key fob then remain on once I turn on the car. Along with the traditional valet switch functions.
    What I am unsure of is if I need some kind of transistor in the highlighted area or if this would work as is.
    Click image for larger version
Name:	3way switch.gif
    If someone could kindly tell me if I'm on the right track or not that would be greatly appreciated.
    Thanks!
    you could get away with a pair of diodes there, to prevent your domelight from backfeeding into your ignition or vice versa. but your 07 civic should have switched ground not switched 12v at the domelight. if you add a relay on that switched ground you can switch the polarity and it sounds like you would be in buisiness
      Thanks I didn't know that it was the negative that was switched.
      So I think I understand the use of the relay (after three edits lol)
Name:	3way switch 4.gif
      Would it make a difference if I were to use a coil or photo isolated based relay?
        i would use a standard spdt bosch style automotive relay and the funky little black boxes are diodes. sorry i dont have photoshop so this is a mockup from paint
          no problem as long as it gets the point across ^_^
          Thanks a lot!
            no prob
              Heres an updated version thats a little clearer for anyone thats interested.
Name:	3way switch5.gif
              So regarding the -12VDC... where is that coming from exactly if the "switched ground from dome light" would be the negative on the light.
                it would be the same as the 12v constant wired at the switch
                  gotcha, thanks!
                    once again no prob
                      could you tell me why the diodes are facing the way they are (lines on the left)?
                      CTS 05, Mobile Information Center...
                      Atom - 1.8ghz
                      2GB Ram
                      32GB SSD
                      8" TouchScreen
                      5.6" Screen (overhead) w/reverse capability
                      Finished Project
                      Car Hacking
                      WorkBlog
                      Video
                        it's indicating current flow as it's depicted on the diode. The current from the 2 sources will be flowing into the switch, but not allowed to flow the other way, so you wont have your dome lights on while your car is on, and you won't burn the wiring for the dome light up while trying to power all the ign switched devices...
                        Crawdaddy
                        1991 Chevy Suburban 1500 w/SBC 350
                        2005 Saturn ION 2 sedan
                        Suburban Worklog
                        "A local New Orleans man says his socks are finally dry..." -Tom Tucker, Family Guy
                          thnx
                          Atom - 1.8ghz
                          2GB Ram
                          32GB SSD
                          8" TouchScreen
                          Finished Project
                          Car Hacking
                          WorkBlog
                          Video
