Car PC Building Experiences ... So Far.
  • Car PC Building Experiences ... So Far.
    Having spent over $3K, I'm feeling like I'm constantly battling flaky hardware or I'm just flat out not doing something right, so I'm hoping someone can provide some insight as to how to do things ... "right"
    Here's what I've done:
    I bought a Car PC case from Mechatronix. I've also drilled the thing to death, so I have two cases that are now completely riddled of holes I feel like this case is right, but there are several things I'd like to do to fix it. First, it would be nice to have a front panel with buttons on it (parallel port controlled is fine) with spaces for LEDs and a USB port. Having had no experience with CAD design, and no pockets full of cash, I can't afford to prototype a bunch of cases for this project - unless I had a set of people interested in buying my design.
    Secondly, I bought a Pico-ITX board. The Pico-ITX board worked great for about 6 months. I figure with the constant fiddling, mounting, unmounting, and changing of standoffs didn't help matters - it ended up shorting out when I plugged in the USB port connectors, and on and on and on. I think the Pico-ITX board is a perfect fit for this, but I am not sure.
    Third, I bought an AMP9-B from 41hz.com. This works great. I have confirmed it works, and the output is perfect.
    Fourth, I bought a laptop hard drive, and some anti-vibration mounts for it. I attached it to some drywall aluminum siding and it fits like a glove. Perfectly mounted, and so forth. It works great, very happy there.
    Fifth, the display - the Lilliput 7" USB Touchscreen - works great. It fits in the case, screwed down, and works beautifully. Linux and X-Windows with the touchscreen works brilliantly.
    I am concerned about several things. First, I bought a 90W power supply (the pico PSU 90W) and found that the Pico-ITX board kept freezing and failing to reboot after I added more than the touchscreen controller and keyboard to the USB ports. If I added a CD Rom or Bluetooth controller to it, it would fail to boot all the way, and would get to a point where the system would flat out not boot until I left it unplugged for several minutes.
    Do I need a power supply that can supply more wattage? I am thinking the PW-200-M would be perfect, as it's 200W and fanless.
    Next, I need a way to tie down the cables securely in the case. I am using tie-wraps, but I have found that the slightest vibration will cause the cables connected to the motherboard to come loose.
    I'm not really frustrated right now, I'm just trying to get a design that works. And I'm hoping someone's used the same case I used from Mechatronix, and used the same type of hardware. I'm not opposed to using a different motherboard, like a Nano-ITX board - I just need to be able to wrap all of the cables and fit everything in the case so that it can be put into the dash.
    I'll take pictures shortly to show what I've accomplished - which with a dead motherboard is not a whole lot.
    I have opted to use some aluminum siding (a 1 1/2" wide aluminum strip bent so it fits in the case) that I can drill into and mount the phono outputs for the speakers and connect the power connectors to the board. It's hard to get this right, I'm happy with how it progressed, but I'm thinking there's an overall better way to do what I want.
    I'd appreciate any help people can suggest. I know this is a long post.
    use hot glue on the cables on the board or super glue. just a little dap after you insert them
    Garry
    Killeen tx
    93 typhoon #1110 work in progress
      You need to break down the power used at each voltage rail: 12V, 5V, and 3.3V. It sounds like you may be too heavy on the 5V, that is what USB uses. You have to look at current needed at each voltage, not 90W vs. 200W
      ~Jimmy
        Apparently, this system has the ability to peak 120W with the mini power supply I bought. I can buy a self-powered USB 4 port controller that will output what I need from a 5V input, which would work perfectly. This way, the power is not sapped from the motherboard, but from its own power connection. I was hoping I could find a "do it yourself" kit with the pieces to solder on myself, but from the sound of it, it's cheaper to buy one pre-made, disassemble it, and mount it.
        This should be lots of fun! w00t!
          Hang in there, frankly if your carputer starts working flawlessly buy another thing to attach to make it screw up. A perfect CarPc is boring.
          Sound Stage
          Eclipse|MTX|Infinity
            OH! OH! What he said! DEFINITELY, what he said!! (While I am looking at that great $1K mobo/case upgrade now that everything is working flawlessly)
            My opinion is my own.
              Do NOT buy one of those Pico PSU's, they don't make it that obvious but if you read around you will see that they don't regulate the 12v rail which with your other PSU could have been the cause of your MB death. Buy a PSU from here, mp3car, trust me I found out the hard way, that doesn't mean you do.
              "Mess with the best, die like the rest."
              Work Log --> Old Car (Totaled)
              Work Log v2 --> New Car (Totaled)
              Work Log v3 --> GMC Suburban K2500 (Engine died)
              Work Log v4.5 --> 05 Toyota Tundra DC SR5
                On the new system I am looking at, they are suggesting this PSU because of "stock" PSU real estate in the case. It looks good on paper. Thoughts?
                http://www.mini-box.com/PicoPSU-120-...=8&category=13
                  Sorry, my bad.....this is the PSU they recommend.....thoughts?
                  http://www.mini-box.com/M3-ATX-DC-DC...=8&category=13
                    It might work if you start your car before your PC because the cranking of you engine drops your voltage to as low as 6 or 7 volts and after your engine has started can run as high as 14-16 volts. So it might work but personally I don't know... Right now there is someone selling the same PSU I have that runs just about everything in my CarPC. Check it out here it the opus 120. And if you want a good basis for building a CarPC checkout the worklogs especially mine...
                      I think this might be a better choice than the M3....also looking at yours....
                      http://www.mini-box.com/M4-ATX?sc=8&category=13
                        Same thoughts on the other PSU... I just don't trust their PSU's I always recommend getting one built for a car environment. Now that Ive said that, they might have changed since I last used them so what I'm saying could be void but it is just my $0.02 after all.
                        EDIT: I was just looking at the new M4 PSU, right before you posted that link... It looks good, has anyone tried it out? How well dose it work?
                          Trust me.....the motherboard alone that I am looking at (w/cpu, ram) is costing a small fortune. I am listening to ALL thoughts. lol
                          IEI KINO-9452 Core 2 Duo Mobile Mini-ITX Mainboard ***
                          - Processor: Intel Core 2 Duo Mobile (Merom) T7200 FSB667 2GHz
                          - CPU Cooler: CoolerMaster EPN-41CSS-01 - Socket 479, Socket M, Socket P
                          - Memory: 2 x DDR2 667 RAM 1GB (2GB Total) -Board must have 2 memory slots
                            The M4 seems promising, I like its design, plus it would give you more than enough power to run everything.
                              I've been using 2x M2-ATX for almost 2 years now (1 for the MB and 1 for accessories/peripherals, both tied together) and not a single problem with over/under voltage nor death to any of the computer parts. Power supplies power on with vehicle startup and pc boots about 5 sec afterwards. All controlled via the M2s.
