12v to 5v 5A Power Supply
  • 12v to 5v 5A Power Supply
    Hello guys,
    I looked a lot of projects, but this is the best, because with this, we can
    provide clean 5v power with 5A.
    I just made the Circuit Board, and mounted in my Honda Jazz to
    supply 3 USB hubs.
    The heart of this project is the LM338k Regulator, with a BIG Heatsink,
    this will get hot quickly... :-)
    After you place all in board, u just need to adjust the resistor, to get
    the 5v in output.
    C1 1 14000uF or 10000uf 40 VDC Electrolytic Capacitor
    C2 1 100uF 50Vdc Electrolytic Capacitor
    C3 1 0.1uF Disc Capacitor
    C4 1 0.01uF Disc Capacitor
    R1 1 5K Pot
    R2 1 240 Ohm 1/4 W Resistor
    U1 1 LM338K 1.2 to 30 Volt 5 Amp Regulator
    This is the link for the original project...
    ( I removed everything before the C1, because we have 12v DC)
    http://www.aaroncake.net/Circuits/supply.asp
    The LM338 is a linear regulator. About 60% of the power in a 12 to 5 volt linear regulator gets burnt up as heat. To deliver 50W to the load 65W is burnt as heat.
    Also, this design doesn't have a disable. It never turns off. Unless you have a relay controlling power to the circuit, your battery is toast! Running off your car's battery without the eingine running would drain it really quickly.
    I linear regulator is very stable and free of power line noise, but it is just not worth the waste.
    If you need BIG power to run your USB system, and want to do it with style and grace just follow the link in my sig. 5V@10A, 93% efficient, USB Sync'd, 300 kHz switch freq, and professionaly built.
    Order your ACPPSv1 Now! 5V@8A DC-DC, computer sync'd accessory power supply.
    My Install
    My other hobby is more dangerous...
      A PT6625 is good for 5V at 5A : http://www.datasheetcatalog.org/data...nts/pt6625.pdf
        Originally posted by Rob Withey View Post
        Ooh, I like that chip... And 85%+ efficient for high current 5v out. Never even knew it existed. Good find!
        1.9in x 2.9in -- 47mm x 73mm
          $36.60 on digikey.com (Link)
          Still needs a little work to become an installable piece, but this will let people with minimal electronics knowlege create a 5V switcher PS for their carpc's in an afternoon.
          My Install
            lm7805
            Another voltage regulator you could use is the lm7805. Its cheap and if voltage between 5-20V is applied the output voltage is a constant 5V.
            VW GOLF MK1
            2.0L 8V
            T3/T4 TURBO
            NOS
              Maximum power draw is less than the maximum draw on a standard USB hub, and definately less than 5A.
              Also it is not very stable over vast ranges of temperature.
              I love and use them all the time, they even appear on the FB.
                7805c
                Point taken regarding the temp. I don't know which type you are using. I have installed one of these..(below). they seem to handle up to 1.5A and you can add a heatsink.
                VW GOLF MK1
                2.0L 8V
                T3/T4 TURBO
                NOS
                  7805c
                  forgot the attachment.LOL
                  VW GOLF MK1
                  2.0L 8V
                  T3/T4 TURBO
                  NOS
