Alarm Pager (delay time)?
  • Alarm Pager (delay time)?
    Im thinking of wiring up an old mobile phone to my car alarms siren so when the alarm is triggered it uses the speed dial feature of the phone and phones me.
    There was someone on the net that says he will mod any mobile phone to do this but he wanted about 100 + plus a phone.
    I've managed to get it going using a 5 pin relay the only problem im having now is that I tried wiring it up to the siren so that when the siren goes of it activates the relay and calls me the only problem with that is that every time you turn on/off the alarm the siren chirps and the thing phones me up...lol
    im starting to think ill need to make a time delay circuit so it doesn't kick in until the alarm has been running for a couple of seconds.
    I've read that its possible to wire a resistor to a capacitor and then wiring that to the relay so that it takes a few seconds for the for the cap to charge before triggering the relay but there wasn't any mention of what resistor or cap that is needed :-(
    Any help would be greatly appreciated ;-)
    Anyone
      555 timer.. google it
      2003 Nissan Xterra Worklog
      Total amount spent so far: $1196.64
      You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
      2003 Nissan Xterra - Modifications
        Thanks for the reply
        I was going to do a 555 circuit but when I went to buy them there was three different types a NE555N a NE555D and a LM555 and I wasn't sure what to buy. Also I couldn't find a diagram for the pins let alone wad caps and resistors I would need, then I come across an old site where someone said that they managed to get a delay using only the caps and resistors but again they didn't say what ones where needed
          The extra letters identify minor details like manufacturer, package type, temperature range, etc. It would be best to get one as a DIP package as they are easiest to prototype with. It would also be a good idea get one with a wide temperature range. So the NE555N or SA555 or LM555CN would work.
            Thanks for the info
            I've ordered some 555 timers but I cant find a diagram on how to wire it up
            All I need is a delay of about 10 seconds (can be a bit more or less) from a 12v source to the relay.
            There's loads of diagrams on the net but none of them are for the simple circuit I need
            Can anyone please point me in the right direction
              Wouldn't it be easier just to use the web to send yourself a text? A phone call will be pointless, you're just going to look at the number and hang up anyway right? Plus with the SMS, you don't need to use another phone.
              Ampie Case
              256 MB DDR2 PC5400
              Xenarc 700TSV - VGA Monitor
              Intel D945GCLF Motherboard
              M2-ATX-HV
              2005 Honda Civic
                Ahhh finally the electronics comes in handy.
                You can make a very unstable timer using a simple resistor and cap circuit. The cap charges and then discharges through the resistor, which takes a determined amount of time. Problem with this is heat variation... changes everything. Your timing isnt too specific though so this should work just fine for what you want.
                555 is overkill for this situation because of the extras required.
                http://www.elxevilgenius.net/08Prjects/processr/RCI.htm
                http://robots.open.ac.uk/ibotz/RCcircuits/
                http://hop.concord.org/amu/amu.mess.act3.html
                2001 Mustang Convertible Worklog
                Indigo Custom Frontend (Flash/Delphi)
                Blog
                Qube v1.3 Now Available at the mp3Car Store!!!!!!
                The simplest IO controller you'll ever use!
                  Delay On circuit using 555 timer: http://clarkson-uk.com/555-timer/operation/frames3.html
                    Thanks for ALL the replies
                    Ill stick with the 555 for now seeing as I already bought them.
                    This diagram seems to be the best one ive seen: http://clarkson-uk.com/555-timer/operation/frames3.html but there are a few things im not sure about like what does T1, RA and C mean?
                    Also there are a few things on the diagram I don't understand so ive edited it slightly and attached it below.
                    Thanks again everyone
                      T1 is the TIME frame of the circuit. If you want a 10 to 11 sec delay then you need a CAPACITOR (C) of 100 micro farad and a RESISTOR (Ra) of 100k. The other capacitor stays at 0.01 micro farad. If you apply power to the circuit (+ -), the output of the 555 pin number 3 is off untill T1 expires, then the output turns on and stays on untill you remove power (+ -)
                        Hi :-)
                        Thanks again for the help
                        What "other capacitor stays at 0.01 micro farad" ?
                        and what do you mean by "the output of the 555 pin number 3 is off untill T1 expires" . I don't know what a T1 is...lol?
                        I've managed to find some 100uf caps on an old motherboard but the only resistors I have are 150uf Will these make much of a difference?
                        Also can someone please help me with the things I have marked out in the pic.
                        Thanks again everyone I really appreciate the help ;-)
                          If you don't understand the instructions or what component is what, you better off not building any circuits.
                            Its the first time ive come across a 555 timer so im trying to learn how they work
                            Im sure you was the same when you started off.
                            Anyway if anyone can help me with the above I really would appreciate it
                            Thanks anyway ;-)
                              People are ignoring me again.
                              Ampie Case
                              256 MB DDR2 PC5400
                              M2-ATX-HV
                              2005 Honda Civic
