Motherboard connectors?
  • Motherboard connectors?
    Where can I buy a motherboard connector for this 7x2 pin connector for my audio. Its the same kind of pins you use to attach a power switch to your motherboard just longer. I can't seem to find them on newegg and I don't know where else to look. I just want a connector so I can have some wires running out the back of it. Attached is a picture of the connector from the manual.
    Would this be close enough?
    Failure is not an option....
    It's installed by default on every version of Windows.
      you can find this connector in every component store, than solder the cables on it...
      "case": Skoda Superb Elegance 1.8T
      Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
        You can also buy them in a form where you can put a ribbon cable between it and use a vise to squeeze it shut so you dont have to solder directly to the pins if you are bad at it.
        1.9in x 2.9in -- 47mm x 73mm
          That is exactly what I need what are those called?
            IDC socket connectors.
