Is it possible to Use a PIR sensor to help on blind spot issue ?
  • Is it possible to Use a PIR sensor to help on blind spot issue ?
    I was thining of doing something that would help me on the blind spot issue.
    So i would like to know if using a PIR sensor (from presence detection stuff) that would light up a led light on my side mirror would be an option.
    Is it possible to use something like these to do what i am talking about ?
    If not, since i dont have a radar, what would could be done ?
    Thanks!
    I PIR detects "moving heat" (ie, temperature gradients moving across its field of view up to a certain distance).
    What about a convex mirror?
    What are you trying to detect (off- or near-side read blind spots for moving traffic)?
      if you are trying to do a blind spot detector, how about using something like
      http://www.parallax.com/Store/Sensor...%2cProductName
      it is an ultrasonic ping sensor, the specs say 3 meter (15ft) range.
      it might work? don't know how you might mount it.
