3G Connected OBD2/GPS Device
  • 3G Connected OBD2/GPS Device
    In episode 2 of the Car Bytes podcast, I made reference to a 3G capable OBD2 device with GPS that connected to OSDash. I think a device like this might be possible to do.
    What it must be capable of:
    1. Be an always on device with minimal power draw
    2. Connect to the OBD2 port and get current status and possibly send commands
    3. Have a GPS module for telemtry
    4. Have a 3G module for wireless connectivity
    5. Provide 3G, GPS, and OBD2 over usb or bluetooth to the host carpc
    6. Optional - Have a few DIO pins for control, possibly include small relays for more powerful control OR connect directly to fusion brain
    Possible hardware list
    1. ELM 327
    2. OBD2 Connector
    3. ELM 327 OR MicroOBD
    4. GPS GSM/GPRS module OR GPS GSM/GPRS module for arduino
    5. Arduino or some other ARM board
    Possible issues
    1. How do we allow pass through on all these devices? Are we going to need multiple ICs, controller chips, or some extreme programming. This is the one getting me stumped.
    2. Arduino USB board only has 1x UART channel, while we require 3x: USB, 3G, and ODB2.
    Going with the Arduino route, all we would need to dev is the OBD2 board, which shouldnt be hard at all. However, the Atmega only has 1x UART, and we have 3x devices that require UART for connectivity: 3G module, USB, and OBD2 ELM 327. We may need some sort of 4 port mux/demux switch or use a different arduino board.
    Let me know what you guys think.
    Start first with the feasibility. When you say, "always on with low power draw" what, exactly, does that mean? 1 watt? .5 watts?
    It's probably easier to translate that from a requirement like: Must function continuously for 2 weeks on standard 12 volts, X amps battery without consuming more than X% of the battery's capacity.
    Then you can do a quick back of the envelope just to see if it's feasible.
    Want to:
      Updates:
      So it seems that people have already done this with arduino, so I think that is the platform I am going to use for now. Link
      As for the power requirements, let me scroll through and let me see what the power consumption is...:
      1. ELM 327 - 5V @ 12mA = 60mw
      2. Arduino ATMega328 - 5V @ 12mA = 60mw
      3. GPS GPRS/GSM board - Unknown, but 3G modules use about 2-4W during data transfer
      So the biggest draw here is the 3G connectivity. However, that is only during data transfer. However, I will limit the device to only use the 3G once every x amount of time. X will be user-settable, so it could be anything. The ELM327 could also be switched off as well and the ATMega also has a super-low sleep mode that only uses ~1mw.
      Lets assume that I set X = 15 minutes. It will take approx 1 minute for the GPS to get a fix, gather all the OBD2 values, and send/recieve all data to OSDash. So thats 4 minutes an hour or 96 minutes a day that we are using the full 2-4W.
      A normal car battery is approx 45 Amp/Hours in capacity. However, we can only go down to approx 70% capacity before we will not be able to start the car. That leaves us approx 13.5 amp/hours to work with. Using approx 3W a day (96 min at 2W) and the car battery having 162 watts to use (13.5A * 12V) is close to around 54 days of use time at this rate.
      However, this might be calculated wrong, can someone check my units and math?
        3watts for 96 minutes of the day is around 0.4amp hours at 12v.
        Edit : math fail
        RevFE
        My Shop
          Edit : math fail
          So..... .4 amp/hours per day will still leave us with around 33 days of active usage at this rate if we only use 13.5 amp/hours of the car's main battery. Still pretty good.
            Check the details on the GPRS/3G data link.
            If you can drop it to only using a 2G radio link (AKA, dropping back to GPRS), then the power draw drops significantly.
            Remember, you aren't trying to download a torrent on this link, just a couple of k in status updates / commands. So if you can use a 2G link, you will find that the power draw drops.
            Bearing in mind, this is just what I have found with using mobile phones for data transfer, if you kill the 3G radio and just use 2G, the battery life jumps by 20-30%
              I have two free usb ports on my router that I can connect a usb obd2 interface to...
              http://www.mp3car.com/vbulletin/gps/...ml#post1347351
              it's not running gpsd anymore since it's crashes all the time, had to write my own multiplexing tcp server that shares the gps com port over tcp.
              up to 100 clients can connect and use the same gps data over wifi or 3g. the same server could share the obd2 com port in the same way.
              the router needs 5v 1.5A to run and power the usb devices.
              more info:
              http://www.koppel.cz/conferences/viewtopic.php?p=10552
                n2k, 7.5W is waaaayyyy too much to draw for this device. It needs to be <.5W while in operationg mode (allowed to go up to 2-3W while in 2G/3G mode). Anything more than an embedded device will draw too much power.
