iPod and iPhone support for all carPCs
  • iPod and iPhone support for all carPCs
    Gauging interest in a custom iPod/iPhone connector cable for carPCs. As many of you know, all the major headunits have special cables that allow them to control an ipod, playback songs (even protected ones) and browse your music collection. If theres interest this product would do exactly the same thing. It would feature RCA cables for left and right channel audio, a USB connector for power/charging and a serial connection for data transfer. There would also be a freely available library for interfacing with the iPod and plugins made available for all the major front ends.
    Note: This would be configured as an automotive accessory connector so when power is turned off the device turns off and locks (could be useful for iPad installs).
    So....whos interested?
    19
    Yes cool idea!!
    63.16%
    12
    Yes but only if it was available for less then $25
    36.84%
    7
    No I prefer using my ipod manually/with an existing headunit
    0.00%
    0
    No I don't even own an iPod.
    0.00%
    0
    openMobile - An open source C# Front End (why choose openMobile?)
    - Always Recruiting Developers -
    Like what you see? Donations are always welcome
    this might be stupid question, but how is this different than say connecting your ipod to a front end like centrafuse via USB cable?
      It depends on the ipod... iPod classics when connected will show up as a removable storage drive in cf and you can play only non-drm protected files. CF doesn't have any support for reading iPod tag info, playlists or pictures. For iPod nano, shuffle, touch or the iPhone, connecting your iPod won't do anything unless iTunes is installed and even then I don't know of any windows front ends that can playback music from your iPod using iTunes.
      Long story short, Apple doesn't let you play music over USB...they have a proprietary protocol that has been licensed to no one. This cable takes the route that all the major headunits use...using the iPod accessory protocol and streaming music over the docks audio output. This allows access to iTunes tag info, library reading and playback of even DRM protected music without any software or OS requirements.
        Doesn't this cable already exist as the Apple audio/video cable? It has the dock connector, USB and audio/video RCA's on it. The software would be the missing part, I believe.
        Want to:
          Nope...completely different.
          The iPod universal connector has three interfaces...a serial accessory interface, usb and firewire. The USB and fireware protocols are proprietary, licensed to no one by Apple, and even if you use the interface library from iTunes (illegally) can only give you access to the actual file system, with no way to decode protected files or playback any files.
          This cable would connect to the iTunes Serial Accessory Bus allowing you to control playback and easily access the internal library. It would also feature the correct resistors and connections to be detected as an auto accessory adapter and allow rapid charging through the USB port.
          More Info:
          http://pinouts.ru/PortableDevices/ipod_pinout.shtml
          http://www.adriangame.co.uk/ipod-acc-pro.html
            If I understand correctly my front-end would display the songs and videos on my iPod/iPhone and I would be able to play/skip/whatever songs using my front-end? Yes cool idea.
            1. What would be the approximate cost? Ballpark figure.
            2. What iPod/iPhone models would be supported?
            3. What would be included in the final product?
            4. What would be the carputer requirements? Hardware and software.
              $25-30 maybe a little cheaper if theres enough interest
              All iPod and iPhone models although the amount of remote control available depends on the model. Very early iPods do not allow library browsing just control and currently playing song info.
              Just the cable:
              Requires an open serial port or an open USB port with a serial adapter-thats it.
                I like this idea, I started building something like this myself (had the hardware working but didn't get very far with the software). How quick is it at browsing large libraries? Some head units can be a bit slow, and when I was building mine and getting data back using a terminal program it looked like speed could be an issue.
                After that experiment, I was going to use the Sharepod Library (http://www.getsharepod.com/) as this seemed easier - no protected file playback still, but has access to the rest as far I can see? How does OM currently do iPod support?
                  I just got the hardware yesterday so i'll probably be digging into it later in the week. From the first look, it looks like you can do baud rate escalation so iPhones and later generation iPods can communicate pretty fast. I would bet the reason headunits can be pretty slow is because they search the iPod in real time. I would asynchronously index the library locally so that after a minute or two of being plugged in, everything would be instant.
                  We use an ipod library I wrote from scratch:
                  http://www.mp3car.com/vbulletin/om-s...d-support.html
                  Protected file playback really isn't possible over USB unless you pipe the files through iTunes and have it all setup but that just causes a load of issues. iPod touch and iPhone thats not even an option though.
                    Ah, that seems like it would work.
                    Yeah, I was never expecting protected file playback, doesn't bother me as I don't have any DRMd files. I do use a Touch though, and Sharepod works with that, so I assume the library does too - from the OM thread, am I reading correctly in that they must be illegally using an Apple Library to do that?
                      Would it work like this, on the Infiniti:
                      [media]http://www.youtube.com/watch?v=ugfyMTc6g-0&feature=youtube_gdata_player[/media]
                      With playlist selection, tag ion and even album art?
                      If so, I would buy two!
                      Worklogs: 08 Sequoia Platinum Carputer (In Progress!)
                      Skin: MetroSex on the Beach preview
                      07 Infiniti Fx35 (done!) & 06 Infiniti M35 (gone...)
                        Yup they link directly to the iTunes coms lib which means that iTunes is required for it to work and its illegal.
                        Playlist selection, library browsing, tag info ..check, check and check. Album art i didn't realize was possible but yea if the data is sent i'll figure out how to decode it.
                          Put me down for 2 maybe more
                          I'm pretty new inside these forums but before I asked the first question I did alot of reading.
                          This thread is why I'm here! I've been working on a design for a cradle but my work will stop. Are you using a 30 pin? is the plug in round or square? I guess what I'm getting at is the holder I've got laid out will have an extension for my Otter box so I don't have to in and out the thing. For a phone I enjoy using I hate it. Plus It's not a great time to jailbreak with new firmware.
                            I'm in also
                              I'm in. Still trying to work out how to truly integrate my spare iPhone into my car. This cable provides that much more flexibility.
                              -Ryven
                              via iPhone
