Ta-Da! Prototype DC-DC PSU
  • Ta-Da! Prototype DC-DC PSU
    This is a new prototype for the FusionPSU! It is based off of the M2-ATX in size, and that's about it. The 5v rail is almost 2 times as powerful, the 12v rail 125% more powerful, and all rails are a minimum of 50% better regulated.
    There is a big easily replaceable fuse next to the big easy to wire to screw terminals. The connectors are modularized, so if you only need the ATX cable and 1 HD, then you only need to connect that making it so that your mini case doesn't become a crowded mess.
    It has the same footprint as the M2-ATX meaning it is a drop in replacement for cases like the VoomPC/VoomPC2. It also has a USB jack on it that will allow for programmable settings and monitoring if wanting. If not wanted, then you don't need it.
    Code:
    Output Rail 	Current (Max)	Regulation
    5V	 	15A 		> 1%
    3.3V	 	8A 		> 1%
    5VSB	 	1.5A 		> 1%
    -12V	 	0.3A 		> 5%
    12V	 	10A 		> 1%
    1.9in x 2.9in -- 47mm x 73mm
    Nice! What kind of settings and monitoring does it support?
    Failure is not an option...
    __________________________________________________ ______________________________
    The only full multizone / multiscreen cross platform open source Front End -> OpenMobile
      this sounds awesome.. cant wait to get one to test it out. I'd love to replace my DSATX with something smaller.
      Live mp3Car Facebook Chat
        It would be cool if you can control the timing of each individual connector. I have my screen powered by my M2-ATX P4 connector, and it would be cool to have it come on (X) seconds after ignition, so you dont get that ugly "NO VGA" screen, and you dont see the post message. Thats the only thing keeping me from having total black until Centrafuse shows.
        1997 Acura CL (Capacitive Touch, GPS, DVD, HD Radio, Backup Camera)
          why not mini usb? that female usb connector almost looks bigger then the caps.
          but otherwise, i like it!
          next project? subaru brz
          carpc undecided
            I see a depressing lack of mounting holes, am I just missing them? Any sort of ETA and price point?
            RevFE
            My Shop
              Currently nothing. But the goal is for it to report back the actual voltages of all rails live at a bare minimum. Settings would be for amp turn on delay, and even sequencing of the power rails. Of course there is the soft off/hard off timing settings as well.
              This was just a one off build to see what I can get going. Once I get this working I will work on making something more "pretty" to have actual beta testers. I haven't checked the specs of the DSATX, but I thought that thing was really really beefy? If you are using it to max capacity, this may not work. What sort of ratings do you need?
              That would be cool, but against ATX regulations. There is a giant document that you must follow to be compliant. But it sounds like you could use the remote amp turn on feed to turn on your screen + amp at the same time. Or you could <cough> get a FB </cough> and have it turn on one or both on boot as well.
              Yeah the connector is gigantic. I just wanted something to play with. But, if you look at the connected directly to the right of the USB jack (the little 2 pin) that is actually D+ and D- for the USB signals. So inside the case, you can just wire those 2 pins over the cooresponding 2 pins on your motherboards internal USB header and that is really easy to do.
                I was quite depressed too when the fab house decided to just omit an entire drill pattern from the board... The USB mounting holes, board mounting holes, and several heat vias were not drilled. Also if you look closely those big through hole capacitors are mounted to SMD pads for similar reasons...
                I don't want to do an ETA because I feel really guilty about the FBv6. If there is a problem, it pushes things back by at least a month. The sooner the better though. Price point should be slightly above the M2 retail.
                  Would adding more features be against the ATX regulation? If you comply to the basics and add more shouldn't that be ok?
                  It would be nice to have one or two controllable outputs that could be either delayed or activated when trigged from software. This would make it easier to keep the screen (or some other unit) off until some software says "ok lets go".
                    No but turning on the 12v rail after the 5v rail is forbidden. But that's why you can use the amp-output (a delayed signal) to switch a relay connected to the 12v rail, to power your monitor (and amps).
                      I'm hoping programmability will be more flexible than the DIP switch timings on the M2.
                      DSATX Specs:
                      Code:
                      5.0 Volts +/- 2% 	12 Amps Nominal, 13 Amps Peak
                      3.3 Volts +/- 2% 	10 Amps Nominal, 11 Amps Peak
                      12.0 Volts +/- 2% 	12 Amps Nominal, 15 Amps Peak
                      5.0 Volts SB +/- 2% 	1.5 Amps
                      -12.0 Volts +/- 10% 	100 mA
                      DSATX is rated at 220w total output.
                      My calculations show the FBPSU (for lack of a better name) at 246.4w total output.
                      Pretty damn beefy, if you ask me!
                      You've got all these modular plugs that are all 12v, I'm assuming.
                      What if you could manually select one or two of them to be part of the ATX chain or separate 12v outputs controlled by a timing delay?
                      That may not meet the criteria for ATX coompliance, I know.
                      Just thinking...
                      Major kudos, Toaster-man!
                      Just don't wire it to your cigarette lighter. We all know what will happen then!
                      How about the Wiki?
                        Thats too bad, never really wanted to mess with relays and what not, why I never wanted to go the FB route for something so miniscule. Sorry I know you didnt ask for suggestions but gotta say em while its still a prototype. Another one about timing, is to have the ability to control the amp/lcd off delay as well, not just start delay. If you have your pc run 15 minutes after ignition for short stops, it can turn just the lcd/amp off with ignition so it doesnt look like you left your system on.
                          This is sounding cool. An M2 is all I think I need but noise issues and a low capacity worried me..
                          Just thinking...
                          What he said sounds perfect though.. Make each of the ports ability to be timed on and off. By default they all come on as standard atx ports so no compliance breaking. Buuut if a user wants they can mess with each one individually to turn different devices on and off at specified times
                            I intend it to be much more so. That always frustrated me with the M2.
                            I didn't realize the DSATX was such low power. I guess I am in the beef class!
                            Each of those plugs has 12v, 5v, 3.3v, and GND. So it can power anything from any one. I will have to think about making a timed output one... I don't know how to pull that off in a small space, I am already physically limited in board space.
                            Thanks! And thanks for the lol and reminder. I completely forgot about that pic!
                            On/Off timing control is what I am planning.
                            The M2 while noisy, isn't all that bad. It is definitely difficult to make a switched power supply not induce noise back on its power source and I am not going to pretend like this won't. I am going to try and reduce that as much as possible, but it is a tall order.
                            That is doable, but it won't fit on that board size. For a drop in replacement of the M2, I don't think it can be done. Perhaps a larger board can be made with the extra features, but I am really going to have to think if there is a creative way to make it happen. And creative usually means expensive...
                              You could make it as an expansion board. Connect it via a cable so an end user could relocate it somewhere else. This would allow you to keep the space requirement but also have the option of controlled outputs.
