Android IBus interface board
  • Android IBus interface board
    About a year ago, my friends bluetooth OBDII reader inspired me to replace the stock head unit in my M3 with a tablet. Progress has been sporadic but has picked up lately. Here's a brief overview:
    Components: Samsung Galaxy Tab (Wifi only), Sparkfun IOIO board, Tab dock, Custom power and I/O circuit board, e46 BMW M3
    Summary: The tablet plugs into the dock which I'm using to breakout the USB and audio connections. The USB data is split off into the IOIO board and audio to a single ended to differential IC amp. The IOIO is basically a microcontroller breakout for android devices. When used in conjunction with the IOIO library, you can write apps that make use of digial I/O, PWM, UARTs, etc. Pretty awesome. And theres a 3A 5V regulator powering everything. This plugs directly into the stock wiring harness which contains power, audio, and IBus.
    New here so hopefully they let me post pics...
    And video....
    http://www.youtube.com/watch?v=iBdQnFnXtgQ
    Comments welcome...they'll give me a chance to respond and get my post count up so not everything needs moderator approval.
    Very cool idea!
      Where have you been hidding...:-)
      Could you please try this iBus app and report back?
      http://www.bmw-planet.com/productsup...IBus-debug.apk
        e39Bimmer: In plain sight.
        Regarding the app, can you give me more information on the app? I'm not sure it would work with my board because the app I wrote has to run a separate thread to communicate to the IOIO board.
          Lots and lots of work for a minor update.
          I found the correct combination of commands to trick the system into playing audio directly from the Tab! Unfortunately it appears I mixed up the ground on my audio connector so I only get one channel at a time. A quick rewire aught to fix that.
          I also re-wrote my Ibus message parser to correctly capture more messages. I was just grab a bunch of bytes, taking the first good message, and throwing the rest away. Java is not my favorite language for this sorta stuff. But with much frustration, I think I built myself a decent IBus logger for android devices. Now all I have to do is eliminate the IOIO board and I could probably cut the parts cost in half.
            nice!
            you may have figured out the last piece of the puzzle. the puzzle being how to use a galaxy tab without the head unit. will that app run in the background?
            how does the steering wheel communicate with ibus? is it something as easy as a resistance value that could be read by the ioio board via the analog input?
            nice nice work!
              Currently the app does not run in the background. The next big step in development will be to change the app into a service. Then I can have it process messages in the background and broadcast anything of interest to whatever other apps I care to write (music player, vehicle info display, etc...). I believe the steering wheel actually outputs it's own Ibus messages. When I took it apart there was a fair amount of circuitry along with the good old Ibus wire in it. So its actually talking serially along with the rest of the systems on the car. No analog voltages.
              As for my audio problems, I just swapped the wires and now have stereo audio from the tab. I was getting a fair bit of hiss but some bypass caps on the boards audio output fixed that right up. I'm thinking about actually going through with a second board spin now to see if I can get away with eliminating the IOIO board entirely.
                sorry, duplicate ;-)
                  And video....
                  Hi, first of all, sorry about my poor english... is very basic.
                  I have intention of comunication with i-Bus in order to read values from i-Bus (temperatures, lights, revs, etc.) and send values to i-Bus (open windows, door, etc.) This is possible only with the IOIO board and one Android smartphone? I need another board?
                  Many thanks at all, and best regards.
