Schematics/Pin Outs/Diagrams
This is a sticky topic.
  • Schematics/Pin Outs/Diagrams
    This thread is for schematics, pin-outs, and diagrams ONLY.
    NO COMMENTS. IF YOU WANT TO MAKE A COMMENT OR ASK
    QUESTIONS, MAKE A THREAD IN THE APPROPRIATE FORUM.
    FORMAT RESTRICTION:
    Schematic Purpose:
    Pictures/Notes:
    Extra Notes:
    Have fun guys
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    S-Video Pin out
    Pin Name Description
    1 GND Ground (Y)
    2 GND Ground (C)
    3 Y Intensity (Luminance)
    4 C Color (Chrominance)
    Code:
    3  o o  4
    1 o   o 2
    4 pin Male
    ill try get an image instead, but for now it will do
      Garmin GPS 4 Pin Connector
      Pin connector as seen from back of unit
      Pin Name cable color
      1 power input red
      2 ground black
      3 data out brown
      4 data in white
      肚子笑痛了
      S60 Install
        gah, no sense of humor.
        Quick method for regulating 12+ to 12v steady. There's a voltage drop off of around 1v or so. Using a 7505 or 7509, you can get regulated 5v or 9v too respectively.
        Note: Less then 1 amp load. You cannot get regulated 3amps by just using 3 7512s or the like, so don't try.
        Chrysler 300 - Fabricating
        http://hallert.net/
          Serial pinout:
          http://hallert.net/
            Auto Power-Up laptop
            Sends a momentary pulse to push the power button when the computer senses the charging go from cold to hot AND it's not already awake.
            Enjoy!
            '03 Escape 4WD:
            -iTox mini-itx mobo, Core 2 Duo Mobile 1.66Ghz; 2GB, 80GB 2.5" HD, DS-ATX
            -Transflective 8.4"
            -XM, iG4, OBD-II (BR-3)
            -Rearview camera with auto-switching (modified cheesbox)
            -Slim Slot DVD+RW
            -RR, DFX 4
              "Valet" switch to bypas ITPS/Opus/CarNetix
              Here is a switch configuration that let's you manually control your PSU. It works for ITPS, Opus, and CarNetix type PSUs.
              MikeH
                Heres the pinout for your normal DB25 printer cable to use for wiring up HD44780 type LCD's
                Ford XR6T blueprint 4.0 L twin cam turbo.
                Xenarc 7" touchscreen M10000 Audigy 2 NX
                ITX 120W PS 80gig HD, 256MB Ram, USB wireless internet/LAN
                Griffin Powermate Panasonic DVD-CDW
                Pioneer 5x7 Four way, 2x12 pioneer subz
                600watt 6chan USA audio AMP
                  relay circiuts.
                  These circiuts you may find usefull to "trick" a motherboard into powering up just after it has recieved batt power thru an ignition relay and a "on pulse" is needed to fire up the atx motherboard connection. There are plenty of other uses for them if you can think of them. Such as dethump power dissconection of amps during head unit turn on, etc.
                    just found this site which lists a ton of connectors and all their relevant pinouts.
                    http://www.networktechinc.com/technote.html
                    has common pc, mac, sun, sgi, paralell, serial, usb, 1394, video, and other connectors i've never even seen before.
                    Previous: CamryAmp 1.0 - 95 Camry SE V6 Coupe (sold)
                    Current: CamryAmp 2.0 - 98 Camry CE V6 5spd (still bench-testing)
                      DIY aux input to some stock radio units.
                      I found this whilst researching whether the 13 pin connector on the back of the stock radio in my 2000 Subaru Impreza Sport could be used as an aux input.
                      Looks like it can:
                      http://www.wakeworld.com/MB/Discus/m...tml?1096256753
                      I'm going to be giving this a go as I want to keep the hud and not have to use an amp.
                      Edit. Tried this, blew my radio up and had to buy another one. Moral:
                      1. Measure pin voltages before, not after you blow things up.
                      2. Connecting +13V directly to ground is a bad idea.
                      2. The pin out of the 13 pin connector on Clarion radios is not the same across all the models with that socket. I've since found a second pin out that still doesn't match my radio.
                        Most pioneer headunits have a IP-bus for controlling a CD-changer. This can also be used for aux input.
                        This website has the pinouts for the IP-bus in general, and directions for how to easily hook up wires to the pins for aux-input.
                        http://www.gutterslide.com/ip-bus_hack/
                        RevFE
                        My Shop
                          Connectors for Nissan Murano, but good for many Nissan / Infinitis... Includes Sat receiver.
                          http://ca.geocities.com/muran0@roger...nectorInfo.htm
                          Murano Sat Radio...
                            A lots of connector :
                            http://www.hardwarebook.net/connector/index.html
                              This circuit waits for a set time and then activates a relay.
                              With the cap that is in the schematic you will get about a 6 sec delay till power on. You can change the cap in this circuit to 470uF for about a 20 sec delay.
                              肚子笑痛了
                              S60 Install
