XMDirect Cable
  • XMDirect Cable
    Well after a couple days of playing with the XMDirect tuner, and doing some research I have been able to make my own cable for attaching the XMD1000 to your PC so you can control it using your serial port using frodoplayer.
    It's actually quite simple first you need to find either a 8 pin mini-din plug or a old style mac printer cable.
    Then you just attach the pins from the 8 pin din to the following pins on a 9 Pin DSUB Connector using the pinouts below.
    XMD -- DB9 Serial
    pin 1 = pin 3 Data Receive
    pin 2 = pin 2 Data Transmit
    pin 3 = pin 5 Ground
    Then after you have those connected you just need to find a source of power which can come from your PC power supply. Pinouts below.
    XMD -- Power supply
    pin 6 = 12v
    pin 7 = 12v
    pin 8 = gnd
    And that is pretty much it. Works perfectly with frodoplayer.
    Images of the pinouts below.
    肚子笑痛了
    S60 Install
    one of these days ill have to get XM
    I GIVE FREE HUGS!
    Buy Sell or Trade
    If my pm box is full, please feel free to call me any time. 440-328-3382
    Thank you
    Forex
    Rate Mp3car @ FXroot.com
      it's worth the $10 a month
      肚子笑痛了
      S60 Install
        is this the same type of cable that is being sold in the mp3car store for 50 bucks?
        CarPc Done.
        HA HA......Is it ever done?
          What cable are you talking about? I didnt see one for 50 bucks
          I GIVE FREE HUGS!
          Buy Sell or Trade
          Thank you
          Forex
            I didnt know the mp3car store was selling one, but this is the same cable that hybrid mobile is selling.
            肚子笑痛了
            S60 Install
              if you want to add status lights for transmit and power use a 200 ohm resistor to a LED hooked to pin 3 and for power use a 500 ohm to another led.
              James Tune
              CEO, Co Founder
              Hybrid Mobile Solutions, Inc
                whoops not the mp3car store
                http://www.mp3car.com/vbulletin/show...light=xm+cable
                CarPc Done.
                  Did you send it the magic word to switch it to pcr mode?
                    wha........?
                    part of me REALLY hopes you are kidding......
                    EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
                    Status:
                    Installed & Working....
                    Custom enclosures
                    Newbie Guide
                      ehh?
                      肚子笑痛了
                      S60 Install
                        Thanks! i'll have to try that.
                        肚子笑痛了
                        S60 Install
                          Excellent info jcdillin! Thanks!
                          www.i-hacked.com Hardware hacking articles
                            What are you talking about?
                              you can do that using a software and not worry about it...
