serial port switch input
  • serial port switch input
    i have just installed my carputer in my 97 grand cherokee, and it has buttons on the sterring wheel for volume up down, and prev/next track, i have all the wiring to the computer for these switches, but i need a program that can see momentary switches on the serial port and convert them to keyboard presses so i can map them to mediaengine. is there anything like that out there?
    I don't know...maybe hack a serial or even usb keypad and assign the buttons?
      Maybe girder Also, search for I-BUS stuff... there's a guy who did some nice stuff with it. I beleive it was serial.
      PowerVoice v1 | NaviVoice Source
      GammaControl v2.4
      SKINbedder v3
      1995 Lexus SC300
        Does it have to be serial? An easy option would be to wire it up to a keyboard controller (PS2 or USB), and you won't need a program at all.
        If it has to be serial, and you can't find any existing software to do what you want, PM me and I can write up some code to do what you want. I might require a bit of bribing though
          I am using a serial port to recieve momentary switch input using girder with the serial switch plugin.
            This should do the trick. The girder solution is better IMHO, highly recommeneded.
            Stealth OEM spyder
            1204 dot net!
