Wiring help, possibly a relay?
  • Wiring help, possibly a relay?
    What I am looking for is a simple way to open a circuit when power is supplied from a lead. This really isn't carputer related but I know you guys are electronics gurus. I need this to get my LED taillights I put on my motorcycle working correctly.
    Chris
    Car=Dodge Neon ACR.
    PC=Cappuccino GX1 Mini-Book - 800MHz, 256MB ,5GB, CD, XP payed $230
    Screen=8" Lilliput XGA T/S payed $360
    ITPS payed $46
    DVD Drive payed $43
    Ebay GPS Mouse + Software payed $52
    yup use a relay. there is a pin guide in this section: http://www.mp3car.com/vbulletin/forumdisplay.php?f=65
    that will help you. Just make sure you get a relay that can take the power - brake lights are quite meaty but you only got one.
      Here is another good site the12volt.com
        Source for Relays
        You can check out All Electronics ( use ) to find whatever relay you end up needing. They are pretty cheap.
          yeah good site. heard a few people mention it
            Help me see if I am correct on how to wire a bosch 5 pin relay with this picture. If the circuit I want to open was hooked up to pin 30 and pin 87a and the wire with current that I want to open said circuit was hooked up to pins 85 or 86 would it work for what I need it to do? It appears to me it would but I switched majors after my first couple of EE classes.
            Chris
            Car=Dodge Neon ACR.
            ITPS payed $46
            DVD Drive payed $43
              my god, where did that pi come from???
                It came from this site.
                Car=Dodge Neon ACR.
                ITPS payed $46
                DVD Drive payed $43
