usb dvd drive
  • usb dvd drive
    Hi all
    Is there anyone out there that is running a usb 2.0 dvd drive in the dash of their car with the computer in the boot ?.
    If so could you please tell me the results of this as i am worried about the distance over usb .
    my computer doesnt have usb 2 so i would have to buy a separate pci card .Which is ok because i have a lilliput,gps and an xbox joypad on the usb 1.1 interface and i dont want them to revert the potential usb 2 line back to usb 1 because of the speed issue when playing back dvd films.
    Does this setup need a powered hub to get that far if it works atall.?
    Thanks in advance
    Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return
    The car
    There are lots of people using IDE-USB2 adapters. Some people also use firewire which in my opinion is better as it is designed for streaming and has a better sustained transfer rate hover USB2 should be ok and is more useful for other peripherals.
    The normal USB range is 5m without a powered hub so you should be ok going from your boot to your dash. One that comes to mind is Gorks Bimmer with a slot load lappy DVD in his headliner connected by firewire.
    Oh try looking in one of the general hardware sections you will find some discussion about this there as this section is for development of stuff so if you were doing a search only int his section would wouldn't get anything.
      Mapower Slim 5.25" USB2.0 Aluminum External Enclosure, Model "KC51SU2" -RETAIL
      And check out for some slim drives
      VIA MII 10000 - 512MB Ram - Dual 2.5" drives, Xenarc 700TSV, Panasonic CW-8132-B, Opus 150, Audigy 2 NX, PowerMate, IOADR1610 10 Relay card
