OEM GPS Modules.
  • OEM GPS Modules.
    Anyone using OEM gps modules ? Garmin 15L
    I just installed this in my case, plus put the antenna which is no bigger than my thumbnail on the roof. This little guy is super small (I'll try and get pics) & has a strong magnet. This is at least two times smaller than any GPS mouse I've ever had, plus it's WAAS capable. I tested to see if it was working using this great tool:
    GPS testing software
    (at the bottom of the page download: GPS Diagnostics)
    This tool auto detects the GPS unit if you don't know which COM port. Basically I took the pigtail and connected it to my Via Epia's Extra 'internal' COM port or COM2. Then I mounted the OEM GPS in my case and used the tool with the machine booted and it got lock, bam OEM GPS..
    The benefits ?? Well read the stats on this little module, low power (3.3v) WAAS capable and faster lock times..
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Looks interesting. How much was it and where did you get it from? Does the antenna just sit on top of your roof, or is it mounted inside the car?
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
      Thats perfect, $90 seems to be the going price without antenna.
      肚子笑痛了
      S60 Install
        [QUOTE=IntellaWorks]Anyone using OEM gps modules ? Garmin 15L
        Yep, I've been using a Garmin GPS25 for about 3 years now, it's a 5v device but quite similar to yours. If Iwas buying a GPS again I would go for the one you have,they just feel more like you 'made' them than those boring mice you just plug into a USB port!
        Steve
        ....Yes, I know it has a stupid name, those crazy Japanese!
          Not quite yet, but I have a GPS25-HVS (6-40V Input) that's going in my install.
          /M
            [QUOTE=mp3oplecarrier]
            Steve
            WAAS standard doesn't work over here apparently
            In da club....
            ALIZEE WANTS YOU.....
            (\__/)
            (")_(")
            Bunny's first poo
            __ U
              Whole setup
              The whole setup cost about 135.00 but really blows away a USB GPS mouse. These GPS mods were designed for system developers and advanced GPS applications.
              If your looking for a completely "embedded" CarPc then this would be the way to go, its great to hear from others that are using this hardware...
              I think the things I like about it most is that, I'm not using up a USB port I'm using up only 3.3v to power it up, it's smaller than any other GPS device (.75 * .5 * .5) L x W x H and its more capable than the normal USB devices you can buy.
              Via EPIA MII
              512MB RAM
              OEM GPS (embedded)
              nLite WinXP pro on
                That's exactly why I went down that route, I want to keep it as embedded and as "stock" as possible.
                My car (SAAB 9-5 Aero) got a stock "sharkfin" GSM/GPS antenna I intend on using.
                Since most motherboards have an serial port header on the board itself you don't have to make any external connections.
                /M
                  I myself am running the Garmin 15H unit 8-40v or something like that. Works great and definitely recommend it. My only complaint is that it looses satelite lock very easily despite have a strong lock under foilage. But I think I narrowed it down to a poor shielding antenna cable. Will be changing that setup soon. Whats the performance like for you? Just wanna be sure its only me and not others in the same boat.
                  Mark
                  Website: http://www.greenpowerenthusiast.com/
                  Car'Puter Project
                  - Xenarc 700TSV
                  - MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
                  - 1x 256MB Corsair XMMS DDR400
                  - M2-ATX
                  - Belkin 802.11G W-Nic
                  - Garmin 15H GPS
                  - WinXP SP2 (NLited)
                    I'm not using up a USB port I'm using up only 3.3v to power it up....
                    Im a little confuse here, From the pic I see, how would this mount in the case? Can I mount it some where in the trunk/anywhere, Does a M10K have an "internal" serial port? and how are you getting 3.3v in the car?
                    thanks
                    [M10K][TinyXP][Roadrunner Frontend][OEM Enclosure]
                    [iGmon]
                    Download MP3 MixTapes
                      thanks
                      yes the m10k has an internal serial port
                      3.3v comes off the ATX power supply
                      [H]4 Life
                      I'm a lesbian too.
                      I am for hire!
                        this may be a total noob post but, care to do a little write up on how you wired this up, etc...?
                        New System in progress:
                        M10k
                        Phaze TD1500 ~> Seas g18rnx/p
                        Zapco Ref 500.1 ~ 12" tc-9
                        Transflective Xenarc
                        My Car Pc Install
                        My Boat Pc worklog
                          I was looking through the documentation and this looks like it is the proper wiring config for the unit.
                          on another note, where can you buy these units?
                          Creoden
                          This posting is provided "AS IS" with no warranties, and confers no rights.
                            WAAS works by using a geostationary satelite to correct your position and give greater accuracy, the problem is that it is stationed above the United States!
                            We will have our own version soon as the European Space Agency is going to position one above mainland europe. The standard for this is called EGNOS and will be compatible with WAAS although you may need a firmware update.
                            Steve
                              Creoden
                              Awesome...looks simple enough to wire up...
                              here is where you can buy one:
                              http://getagps.com/products/gps/010-00240-02.htm
                              M10k
                              My Car Pc Install
                              My Boat Pc worklog
