How to make LED's flash?
  • How to make LED's flash?
    How are you going guys
    I have been doing so reserch on but have not been able to come up with anything. i want to make some kind of circuit that will alow me to control the way led's flash, or make it flash in a pattern. so far all i've been able to find is that i need a chip. but i need info where to buy it and how to program the chip.
    I will me really thankful if someone can give some ideas how to do this. keep in mind i want to run this from my car at 12v.
    I find the following link useful when building circuits.
    http://www.discovercircuits.com/
    Hope this helps.
    Prem
    Re-boxed Dell Optiplex GX110 PIII 733 256Mb RAM
    Modified Sproggy PSU
    Custom made automatic start-up/ shut-down controller
    Dual 2.5" HDDs
    Laptop DVD Reader
    D-Link FM Radio
    5" PSOne LCD
    Installed and working. 75% complete.
      Turn them on and off *really fast*.
        parallel port interface...and control them with some custom software....
        rebuilding carpc... kinda..
          Agreed. Depending on how much control you want, using your carputer would give you the most flexibility with flash rates and patterns. Using the parallel port would eliminate the need for a chip. Individual LEDs can be driven directly from the port's pins. A string of LEDs would be controlled by a transistor connected to the port's pins to give you more current for the LEDs without the possibility of damaging the port.
            When i get home i'll give u instructions and code to make the LED's flash on and off from the parallel port
            Just wait a few hours tho cause it's 9:50am and i don't leave work till 7 so i'll be home at 8 or 9
            CarPC Status:
            GPS: 99%
            Hardware: 99%
            Software: 92%
            Case Install: 99.9%
            Dash Install: 100%
            Car Install: 72%
              Thanks for the info so far. NIN^ ^NIN, i will appreciate if u can provide me those instructions.
                A 555 timer works great for simple flashing jobs and I am sure you can find even more circuits on the discovercircuits site. Here is another site for you.. link .
                  If it doesn't matter how fast or anything, I'd just buy blinking LEDs.
                    Hooking leds up to the computer is a bit overkill if you just want simple blinking... I've seen led strips with a potentiometer monitoring how fast it blinks, etc... but this was at a surplus store, so no link to give unfortunately
                    I saw some LED strips at walmart one time that light up with the music as well... you may want to check there.
                    Current:
                    2011 Black Jeep Wrangler Unlimited Rubicon | 20" KMC Rockstars | 35" Nitto Mud Grapplers | Rugged Ridge XHD Front Bumper | Kicker KX350.4 amp
                      Use a christmas light
                        @jceli728 - How about going into more detail about what you are thinking/planning on doing?
                          Like... uhm... MIRT fast?
                          1984 BMW 323i (E30)
                          [==========] 90%
                          EPIA MII10000
                          256MB RAM
                          40GB 2,5" HD
                          Lilliput 7" TS
                          Hacked Travla C134
                          Haicom CF GPS
                            Well, after years of "practice" using advanced training material (read: lots 'n lots of porn), I can say "yes."
                            At least with my right hand.
                              Thanks for the feed back. yes i'm trying to stay away from hooking them up to my pc. What i'm really looking to do is for a show purpose, for ex: i have put them in the interior door handles, now i'm able to turn them on with my headlight switch or with an independent switch when the headlights are off.
                              but what i want to do is make them flash back and forth between the doors & create different patterns in the rest of the car almost like strobe lights. i know it will just be much easier using strobe lights but for the place where i'm installing the LED's i will not be able to install a strobe light.
