Via's Mini-ITX IR Module for $1
  • Via's Mini-ITX IR Module for $1
    Check this out!
    This is a schematic for a IR module that costs, well not $1 maybe $3, and probably works with VIA's Mini-ITX onboard infrared connectors!!! I will build it and check for you! It doesnt cost much so if anyone finishes it before me, will not be mad
    http://www.hardwaresecrets.com/article.php?id=86
    Time displayed in a different way!
    http://www.lares.dti.ne.jp/%7Eyugo/s.../03/index.html
    http://www.humanclock.com/
    FREE 3D Glasses: http://www.rainbowsymphony.com/freestuff.html
    Does this really work?
    Did you build it and tried it?
    i searched some infrared recivers and transmitters a long time ago (When i had a color Handspring visor... ahhh...) and these things were much complex than this little circuit...
      I'd be really happy if that does work... but in the manual for my epia it says that the FIR and CIR headers are NOT standard (and to consult them for reference designs), like it is on most motherboards... so if it's designed for a standard IRDA header like you would find on other motherboards, then it may not work on the VIA boards... of course, I only have an epia 800 so it may be different for different models...
      But don't take it from me! here's a quote from a real, live newbie:
      Originally posted by Viscouse
      I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
      eegeek.net
        Printed! i think i'll head down to radio shack to see if they have the parts, i have a few remotes i'm not using
          very interesting!!!
          http://card.mygamercard.net/gbar/car...theberetta.gif
            any results? bout to go nutz with Ipaqs in the car
            92 Subaru Legacy Wagon
            Epia MII12000 :D
            Morex 80W
            120G External HDD
            16x2 Charater Display
            Creative IR Remote
            VIA Sereniti 2000 Mini ITX Case
            7.2Ah SLA Tank
            PCMCIA 802.11b
            256DDR Ram
            Diamonds are for girls- wise men follow the stars
              Have bought the components, but high fever and this bloody headache doesnt allow me to concentrate and built it
                I've made a very similar circuit for a microcontroller/universal remote circuit. Looks like it'll work. Problem is that the cheap IR LEDs aren't very powerful and are required to be right next to the receiver.
                PCChips M789 v3 w/ Samuel 2000+ S3Vid Lan AC97, 40 GB 7200PRM, 512 DDR266, Xenarc 700YV, PAC AAI-GM9 Headunit Adapter, Sirius Sportster, touchpad mouse input.
                  i think i'll try this also.
                  i have a treo 650 and this is a good way to transfer pics or an mp3 or two.
                  thanks.
                  2001 Acura CL traded for a 2006 Subaru Legacy GT
                  7" Lilliput Touchscreen
                  NANO-ITX+m1-atx
                  512 DDRsodimm
                  60g SATA Laptop HD
                  4x Apple DVDslot
                  digimoto OBDii
                  mS GPS
                  mini BT keyboard
                  relocated HU faceplate
                    has anyone tried to get this to work?
                    thanks.
                    NANO-ITX+m1-atx
                    512 DDRsodimm
                    60g SATA Laptop HD
                    4x Apple DVDslot
                    digimoto OBDii
                    mS GPS
                    mini BT keyboard
                      Whilst this looks like a nifty circuit, if you checkout the WinLirc (Windows users or Lirc for *nix users) project.
                      The circuit is as simple, if not simpler. Whilst the circuit is primarily for a com port, there are some variations for the FIR/CIR ports as well.
                      I've built the receiver only portion and have it directly connected to the com 2 header pins on my mobo (looks very OEM, apart from the piece of veroboard the components are soldered to).
                      Works like a charm.
                      Caputer Mk. II
                      '02 VX Holden Commodore Series II Executive
                      MII12000, 512MB RAM, 60GB HDD (5400rpm), 16X DVD, TS200V
                      Morex 60W DC-DC, Custom S/SDC
                      OS/Software: Developing...
                        Well, does it work on via epia cir/fir connector?
