Car Start on Finger-Print Recognition?
  • Car Start on Finger-Print Recognition?
    Would it be possible to do this?
    Either 1) Wire a Finger-Print scanner to the pc, so it only boots if a fingerprint is picked up, then start the car, via a line out(LTP?) to a relay, would mean PC would be on before Car PC
    Or 2) Wire the scanner to the relay for starting the car directly, then the PC boots like normal
    In the first case you'd need a button to start the car, but in the second one it'd just start when the print was recognised.
    These sites may be helpful, Print-Readers or Bio-link U-Match
    Edit: I also just found this, which may be of some use, considiring it dosent need the PC to be on
    Penguin Friendly - tyrion - David Dolphin
    Try searching the forums with terms "fingerprint". There's a big thread on the MS fingerprint reader there.
    Want to:
      problem with going straight from the scanner to ignition is that you would have to have a dedicated system. one idea is that there are scanners for home doors that controll relays to unlock the door. you may try something like that and just run the relay connection to the ignition. personnaly id just run straight through a computer with biometric login and a startup program signaling relays through one of its ports.
        Ok, I wrote a program to put on the CPU of the UniFingerô SFM3000.
        Its written in BASICA or GW-BASIC which is the only code I know off by heart, here it is, please point out any mistakes
        Code:
         10 if in5<>1 and in4=1 let x=1 else let x=0
         20 in in1=1 and x=1 let y=1
         30 if v=1 let y=1
         40 if x=0 let y=0
         50 let v=0
         60 gosub 170
         65 if in3=1 and in2=1 let y=0
         70 if y=1 and in2=1 goto 90
         80 goto 10
         90 let y=2
        100 let v=1
        110 for w = 1 to 50
        120 if in3=1 goto 10
        130 next w
        140 gosub 170
        150 let y=1
        160 goto 10
        170 if y=0 let out1=1 else let out1=0
        180 if y=1 let out2=1 else let out2=1
        190 if y=2 let out3=1 else let out3=1
        200 return
        Here are the varibales and inputs I'm using (you can use 8, which i have 5 in, 3 out, though out1 is probabally unnecissary)
        Code:
        in1	Thumbprint Match signal
        in2	On/Off PTM stitch
        in3	Engine running sensor
        in4	Drivers Door PTM (Closed gives value of 1)
        in5	Alarm Indicator singal (1 is alarm on)
        out1	Off
        out2	On/Drive
        out3	Ingition
        v	Remember ignition position from loop
        w	loop
        x	Door and alarm OK
        y	Key state
        The line ins or outs may have to be linked to relays or optoisolators
          just remember to take care of your thumb... if someone cuts it off they can run away with your car
          Brushed Metal for Centrafuse 1.4
          Brushed Aluminum for Centrafuse 1.4
          xenarc 700ts | via epia-m10k | audigy2 nx | holux gm-210 | usb wifi | 40gb 2.5" | slot-load dvd-cdrw | morex 3688 | opus 150w | centrafuse, iguidance
            we will need to keep a spare thumb ;-)
              actually, you can bypass the fingerprint biometrics with a gummybear.
                It would be proably be best to use an aftermarket car remote start system. There is more to starting most cars then just the ignition wire. Many remote starts can be activated with a neg pulse and that would cover all the relays, safety shut offs, starting and stopping the car.
                  gummybear? ill have to try that out sometime.
                  and yeah, you should keep spare thumbs in your wallet, just in case you leave yours inside your car.
                    Fingerprint car immobilizer
                    Hello,
                    look what i found...fingerprint to start cars..
                    visit www.automobile-security.com
                    Looks real..
                    what do u guys say?
                      Originally posted by peterthomas
                      Hello,
                      Looks real..
                      what do u guys say?
                      PRetty cool. It appears to be a remote start and/or keyless entry that uses a fingerprint reader instead of the traditional remote on a keychain. Their mounts are pretty ugly, though.
                      It also doesn't have a full-fledged PC that's on all the time sucking your battery down to the point of inoperability.
                      How about the Wiki?
                        It sounds cool but after working with biometrics in a hospital primarily for medication security, there is no way I would use biometrics to secure anything I wanted to reliably access. I'm sure there are overrides, but the failure rate of the hardware (the biometric reader) is horrendously high.
                        It's great when it works but a PITA when it does not!
                          Any bad guy who has seen the movie "Demolition Man" is gonna get ideas...
                            the new lexus ls400 has fingerprint recognition, but i think it only unlocks the car.
                            2001 Acura CL traded for a 2006 Subaru Legacy GT
                            7" Lilliput Touchscreen
                            NANO-ITX+m1-atx
                            512 DDRsodimm
                            60g SATA Laptop HD
                            4x Apple DVDslot
                            digimoto OBDii
                            mS GPS
                            mini BT keyboard
                            relocated HU faceplate
                              spammer!
