Steering Wheel Control
  • Steering Wheel Control
    I've but haven't found a useful thread regarding how to make the factory steering wheel audio controls buttons functional, when a resistor network is used. I don't want to use the IR solution, but need something that can make these different voltages into simple keystrokes. Is it doable?
    welcome to the foums. you should find it if you searcha bit more because i have asked the same.
    you need an analogue input board, and connect that to the resistor network, you can then set diff voltages for each action.
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
      just looked at your thread (Corsa ....), but swix solution is IR. The gamepad solution is not possible because these buttons aren't seperate. It is just 2 wires, when buttons are pushed:
      Vol - 54 Ohm
      Vol + 147 Ohm
      Mode 1036 Ohm
      Mute 2007 Ohm
      Preset 562 Ohm
      ^ 300 Ohm
      No buttons pushed 5kohm
      I'm sorry if I didn't understand you correctly.
        Spent so far: $1,755
        Check Out My Work Log for Specs/Pics
        CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
        Don't mess with Texas.
        It's not nice to pick on retards!
