12v PSU output
  • 12v PSU output
    Can anyone see any problems with using the 12v rail from my M1 to power a circuit board I have cooked up. It has a bunch of relays that control an electric motor. I'm concerned about the inductive load dumping a load of power into the other items on the rail when it is shut off.
    Anyone got any thoughts?
    (The board controls the motorised screen I manufactured - I can supply a circuit diagram if anyone is interested)
    shouldn't be a problem.
    PowerVoice v1 | NaviVoice Source
    GammaControl v2.4
    SKINbedder v3
    1995 Lexus SC300
      As long as you're using the 12v to power the relay and NOT the motor itself, yeah.
        cheers guys!
          BTW if that's a home-brew motorized screen, I'd definately be interested in seeing how you did it.
          Want to:
            Dont forget the diode across the relay. I did and fried my Mo-fo-Board
              I'll take some pictures - having a bit of a nightmare with the limit switches but should have it done by the weekend
