CoOl Hard Drive Enclosure
  • CoOl Hard Drive Enclosure
    Cool way to secure a hard drive. I have an older version of this without the front external ide,sata and power connections. They just came through the the cover then. As far as heat goes I haven't had any problems.
    http://www.3dgameman.com/forums/showthread.php?t=37261
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
    Looks nice, but why the need to double post??
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
      Dang I didn't mean to do that they should del the other one my bad...
        damn ur not a noob so i cant bang on u lol
        ive got something like that but it takes a 3.5inch drive and turns it into 5.25 wit heatsink rails on the side and a plate on the bottom it worked pritty well ive got it somewhere here
          I got the encolsure to reduce total vibrations to the drive. So far it has worked great. I also like that I have only the CPU fan and the PSU fan going so that then I have less noise comming from the back.
            What is the price of that thing??
            Thanatos.
            RexBruMet Skin for FrodoPlayer
            Nissan Aux-in MOD
            Originally posted by bgoodman
            We're an international forum, post in whatever langauge you like.
              I think it can be had for like 40 bucks I know I know but still I think it helps clean the install look up alot also. I built a case out of wood and used the wood vinyl peel and stick to coat the inside of the case so it looks cool and this helps the look. Pictures comming...
                Did you have trouble before using this device?
                What issue did this solve for you?
                TruckinMP3
                Read the FAQ!
                  I wonder if the shock absorbers are sized only to handle the resonance from the drive or if it could handle mild shock from external vibration...
                  - Jeff
                  95 Mustang GT Convertible
                  87 Mustang GT Convertible
                  My Project | Let's Go Mets! | SCT Tuners
                  Project Status [===#===] [Bezel and dash creation]
                    Matches the Ampie, best selling point.
