someone please help me find this cable
  • someone please help me find this cable
    I accidentaly damaged it trying to disconect it.
    htis is what it says on it
    AWM 20768 80C 60V
    it connect shte vga controller to the LCD itself.
    also... how the heck do your disconect this thing?
    It would really help if you'd say what LCD you got that from.
    See attached pic.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
      Its used in lots of things, usually only in a few sizes so you should be able to find some in an old printer or scanner that will fit.
      If not get a wider piece and a craft knife......
      Lez, more widely known as flez1966
        Its called a flat flex cable. They come in varying lengths, and varying number of conductors. And they are seperated into different pitches (the distance between contacts)
        It looks like a 1 mm pitch, something like 50 conductors. So all you need to do is measure it, and go here:
        http://www.mouser.com/catalog/624/1046.pdf (Towards the bottom are the cables)
        2000 Subaru OBS
        Dell P3 @ 900 Mhz
        7" Lilliput TS w/DigitalWW in-dash mount
        80GB External HD
        I am Zero Bitrate....
          thanks guys, and im sorry but i dont even know who makes the LCD all i know is the model is a VM80. i bought it from mini-box.com or something like that. my new computer just showed up from UPS like 4 seconds ago that i ordered from the mp3car store... cant wait to start putting it togeather.
            more pics of just the cable
              How many filaments?
              Digitakww sells a 40 filaments, I have a extra 20+ filaments that can work for you... or not. (depends on the answer to the question above)
              Thanatos.
              RexBruMet Skin for FrodoPlayer
              Nissan Aux-in MOD
              Originally posted by bgoodman
              We're an international forum, post in whatever langauge you like.
                btw i counted and it has 40 wires in it.
                  in the second picture oyu can see wee its damaged. a small slit right below the blue section. it took outthe color blue on my monitor... everything is really pink now... and i dont like pink too much :P
                    Like I said digitalww is you answer.
                    Thanatos.
                    Nissan Aux-in MOD
                      kiltjim is 100% correct. You need a flex circuit, its must have 40 conductors. Measure the distance from the edge of one conductor to the other. It should be in the range of 1mm, this is your pitch. all you need to do if find the length and order it from mouser.
                      Peace
                        i think i may have found one on digitalww
                        http://www.digitalww.com/ribbon_cable_oppositeside.htm
                        i e mailed them and sent some pics to make sure its the right thing.
                        thanks for the link
                        btw heres my new pc i got from the mp3car.com store today from UPS
                          well i used a razor and shaved away some of the coating and then cut off about na inch of the end of the cable. then tried it out and to my suprise it actually works. the picture is perfect now. but i still htink i should get a new one.
                          but thanks for everyones help.
                            I like the creativity in doing that. That is what it takes to be able to do something like put a PC into a car.
                            A new one might be better but if it seats fine, does not move much, and it is long enough, should be good for a while. But don't let me stop you from buying a new one if you want.
                            Just had to post that I got a kick out of the solution.
                            My 95' Saturn Project
