USB G Wireless Network adapter with removable antenna? Does one exist?
  • USB G Wireless Network adapter with removable antenna? Does one exist?
    I can't seem to find one...
    BossTone74
    You can replace the factory ant. of the engenius usb adapter with one that have SMA connector or you can always mod a female connector to the USB adapter.
    Check here for the engenius USB adapters specs:
    http://www.keenansystems.com/store/c...roducts_id=137
    And here for a review of what you need to do the MOD:
    http://www.carnetix.com/WUSB11/Page.html
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Originally posted by bgoodman
    We're an international forum, post in whatever langauge you like.
      I was hope someone knew of one that I didn't have to mod...
      BossTone74
        They probably don't make them because they usually come with a USB extension. They tell you to use the extension and reposition the whole unit up higher for better reception.
        ~Jimmy
          several do.
          keep searching
            Thanatos.
            You can BUY that one.
            Michael
              Jimmy, the extension part is true, however that is not going to improve the quality of the antenna.
              Greenman....WHERE????
              Michael I would have to do a mod for that one, I don't want to mod it ...
              BossTone74
                BossTone74
                  http://cgi.ebay.com/NEW-BUFFALO-54Mb...QQcmdZViewItem
                    Am I reading it wrong.
                    "Engenius Senao 200mW 802.11G USB 2.0 EXT SMA Conenctor $99.95
                    EUB-362 EXT
                    Click to enlarge
                    Works in netstumbler
                    Verified working under Linux using ndiswrapper on FC4
                    Click here for linux howto
                    Includes detachable antenna and usb 2.0 cable
                    SUMMARY: For users who require the maximum range and performance, the NUB-362 EXT is the solution with its 200mW high output power, removable antenna,"
                    The website says it has an SMA connector, and it says it is removable in at least 2 places. What more do you want?
                    Michael
                      Thanks for the info guys I appreciate it!
                      Michael, I was confused with thanatos link that he provided it seemed as if one would need to do that mod in the link for it to work.
                      BossTone74
                        No problem. I got worried for a while that I was seeing things. Also, I think he had 2 links, the other needed to be modded.
                        Michael
                          One link with a USB adapter with ext connector and other link with a "how to do" MOD for how to make it yourself
                          Thanatos.
                          Nissan Aux-in MOD
                            I just recently bought this one: http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5852121599 for $40 and am pretty pleased with it. I also bought a magnetic mount external antenna (7dbi), but the antenna that came with it actually does a much better job.
                            http://sonatapc.blogspot.com
                              Buffalo makes a sweet one... its usb 2.0 and takes a mc something connection which you can pick up a magnetic antenna on ebay for 15 bucks... I got my buffalo for dirt... think 19 on ebay. Range is pretty dang good. I was picking up wifi from about 300 yards through my house with it.
