Cubid CB3688 - No Slim RAM ?
  • Cubid CB3688 - No Slim RAM ?
    Hi,
    Is there space enough to have a standard RAM in this chase?
    On pictures there seems to maybe be a problem with the RAM and DVD ?
    Will use Epia 13000, slim slot dvd, slim hdd.
    Daniel
    Well I have a 3677, which has the same insides as a 3688, and i am using regular ddr ram without any problems. I dont have a slim cd drive, or a slim hd, but i can put the tray where the cdrom&hdd drives go without any problems, using regular-sized ram
    El Volcho is in progress...
    Got almost everything
    -Via EPIA M10000, Super 7'' Touchscreen, Morex Cubid 3677 Case, Fujitsu 40Gb, 512DDR RAM, Sony DVD-CDRW...
    Planning 80%
    Parts 60%
    Building 40%
      Yes it uses standard ram. I'm using: Kingston 512MB DDR400 PC3200 KVR400X64C3A/512 $43.99 .
      http://home.comcast.net/~srcstc/my_new_CarPuter.htm
      -Rich
      http://www.mybimmer.net
        Straight from the spec for the Morex 3688 case:
        Memory Height Restricted to 1.250"
        If it is any taller, it will interfere with the metal brace that holds your hard drive and optical drive over the mobo.
        ~Jimmy
          My brother bought that case and the the pins on the front USB hit the caps on the M1-ATX. I will have to desolder the connector and resolder it so the connector sticks straight up from the board.
            It is easier than resoldering. Lookie here:
            http://www.mp3car.com/vbulletin/show...08&postcount=7
            ~Jimmy
              lol.....nice thanks for the tip
