Fanless Heatsink Pentium M / Celeron M
  • Fanless Heatsink Pentium M / Celeron M
    I am looking to make my new upgrade fanless. I am having trouble finding a fanless heatsink made for a Pentium M / Celeron M class processor. Any help would be great.
    I did search but people seemed scared to try this sorta thing which I am not.
    Check my install I am not a
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
    I wouldn't risk running either CPU without a fan. That's just a bad idea.
    How about the Wiki?
      It will be just fine I just got to get a good sized one. I I might mount rods parts of the car to disapate heat more. I really want zero fans.
      thanks
        Then be sure you have a pentium Mand not a celeron M (celerons M can't throttle when heat becomes a problem, IIRC)
        Now Galileo is real. Muhahahahaha :p
          I got a Pentium M 1.6 2mb for 66 bucks!
          http://www.newegg.com/Product/Produc...82E16835114032
          thats the passive heatsink I am going to use
            I think you'll have thermal problems in short order.
            How about the Wiki?
              People also would call me crazy for not cooling my psu and it has been fine. I don't have it mounted in its casing so its out in the open.
                Look at this monster I wonder how well it would do
                http://cgi.ebay.com/Scythe-Ninja-Fan...QQcmdZViewItem
                I have alot of room vertical its just my depth and the width.
                  Just make the lid to the case out of a big heatsink and then run heatpipes from the cpu to the lid.
                  That's how I'll do it anyway.
                  /M
                    You just have to remember that cars bounce around alot and the taller and heavier you get, the greater risk of something breaking increases...
                    As long as you get a good quality fanless HS you should be fine, but undervolting the cpu might be a good idea, just .025v could drop the temp 20C depending on conditions... Might want to check out aoaforums.com for good fanless heatsinks the people there are very knowledgeable and have extreme cooling needs which makes it one of the best sources
                    Debating on installing a carpc in my Jeep.....
                      Theres a fair chance that a 1.4 ghz Pentium M can work @ 1.1V, may be less.
                        remind me again why having a fan is so bad??
                          I would say it would be for a silent pc install, not that these newer HSF's are very loud
                            its for a carpc.. where the environment you are installing the pc in is far from 'silent'... there are soo many HSF's out there now that run super quiet.. Alot of bios' will also change the fan speed automatcially to keep it as quiet as possible and only up the fan speed as it needs to dissipate heat...
                              yea but this community has a wide variety of styles, I am installing a watercooling system on my pc soon... But I do beleive depending on what climate you are living in it would be the best idea to have at least a HSF
