Boost Gauge
  • Boost Gauge
    I wanted to either find for purchase, or design and build, a boost gauge for my car, so rather than having a gauge sit somewhere on the dash, I could have the readout on my screen.
    I know Phidgets has a PSIG meter which you can use with an API setup. Does anyone else know of other solutions or somewhere to purchase something pre-made?
    I just need 0-20psi.
    Why not use OBDII?
    Renault Megane...the OEM look
      You can't get boost pressure through ODBII. You would need a proprietary protocol that is car specific to be able to read boost.
        I think I'd personally go with the Phidgits option. You'd need to build yourself a front-end for it, but at least you wouldn't have to worry about drivers and all that.
        BTW, what kinda car? Being a gear-head, I'm just curious.
        To find your favorite restaurants in Houston, check out http://www.thehubgrub.com.
        If it's not fun, you're not doing it right!
          2005 GTO CGM-M6
          Can't use OBDII for the reason he said above, plus, the car doesn't come stock with any boost devices
            you could use a regular boost gauge and have a shaft encoder on it to the PC. Or look for a pressure transducer. quite easy really but the former is easier to calibrate in a way.
              the gauge wouldnt be able to turn a shaft encoder
              New System in progress:
              M10k
              Phaze TD1500 ~> Seas g18rnx/p
              Zapco Ref 500.1 ~ 12" tc-9
              Transflective Xenarc
              My Car Pc Install
              My Boat Pc worklog
                Take this article from Audi world and work from there http://www.audiworld.com/tech/elec94.shtml
                Also boost data via OBDII is going to be way to slow to be useful.
                  yes it would. i bet you.
                  optical ones have no drag.
                    i didnt even think about an optical encoder. you are correct sir!
                    M10k
                    My Car Pc Install
                    My Boat Pc worklog
                      hehe wanna know a secret....me neither at 1st...had to think to get myself out of that one!
                        ha.. ok, well since we are getting all 'dr phil' over here and being honest... i never even heard of an optical encoder until you posted it and i did a search :-) they are pretty cool... now how can i use one in my setup! :-)
                        M10k
                        My Car Pc Install
                        My Boat Pc worklog
                          haha love it.
                          the other option is a pressure transducer. Honeywell do some with RS232 interfaces but all you need is to interpret the signal - probably resistance which you can do with most I/O boards, phidgets, joystick port etc etc
                          hell you could always take the optical enocder out of a mouse scroll wheel or off the ball and use that!!!!
                            Might as well use a pressure sensor such as MPX4250AP, changing output voltage with pressure, cost about $20.
                            Amplify the voltage (if needed) and send the measured pressure to PC, use serial or USB, easily done with PIC MCUs.
                            http://www.vpv-motorracing.com/MPX4250AP.pdf
                              Opps
                              He want premade
                              Ignore my last post
