police laptop\radio frequency
  • police laptop\radio frequency
    would there be a way to locate police cars by the laptop frequency or radio frequencies? im not talking about like a pinpoint location, but just knowing if there is a police car within a certain distance of you?
    Not really, because you'd have no way of knowing whether the radio or data signal is coming from teh car, the police station or bouncing off a repeater.
    How about the Wiki?
      Hey DP, you didn't even tell him to search. Just so the OP knows, there was a thread VERY similar to this a while back. You should search and see what happened.
      Michael
        Like the others said, this has been discussed before, but...
        Personally I don't have a problem with that, I get false alarms all the time from my radar/laser detector
        [shameless brag] Bel ProRemote Plus RX75 plus, replaced the Passport SRX when they got bought out, X,K,Ka detection, 3 remote laser receivers/blockers [/shameless brag]
        With either case, you could program a database using a GPS and mark all the false alarms. ie, cut the "alarm/make noise" wire and splice in an XOR from a line coming coming from a GPS-based device that you would have to create, most likely in software (xor should work fine, it would alert you to locations not programmed in the GPS, or locations that are in your GPS database but no longer emitting radar/RF).
        The other problem people cited is not being able to "triangulate" the cruisers, especially if they're moving. Well, actually, the fact that you (and maybe they) are moving makes this possible, but you'd need some advanced algorithims to do it. But that's really a luxury feature, knowing the proximity (but not exact location/direction) of the cruisers would be enough for me.
        I wonder if a superheterodyne type circuit would emit enough EMI to have them notice you using it... Otherwise this type of detector would be awesome. My detector is great, but the worst is when cops use instant-on Ka band in an area without much traffic, and where I can't see them until it's too late. Plus, those times when you pass a cop who isn't even doing a speed trap (usually I see them in advance, but...).
          The more I think about it, this would be a PERFECT excuse to build a custom software-based radio!!!
          tunable superheterodyne --> ADC circuit --> computer analysis
          I wonder if GNURadio could be adapted to do this type of thing
          It's probably overkill, because we just need the strength of the signal, and don't need to demodulate it [unless we are going to make a software-radio police scanner ]. But still, people have wanted a computer-based radio for awhile...
            Umm.. It isn't about false alarms. They use repeaters to propagate the signal accross the area. Therefore, you really wouldn't know...... but go for it, I guess.
              see, i was thinking about that, but using the GPS unit in each squad car. But hten only certain jurisdictions have that and each is different, so...it wouldnt work outside of one particular area.
              Carputer Progress: Here we go again...
              THE GF THEME
              Genesis has speed
              Genesis has class
              Genesis sent money
              before your a__;)
              Join the fight against carputters. EMAIL ME!
                You idea about Jurisdiction difference is true, but really, you can;t get that far into the analyses, because there is no way for you to access the GPS data.
                Remember that GPS units DO NOT TRANSMIT. They only recieve. The GPS information is sent on the services DATA radio network. Unlike the old motorola systems, in particular the MDT systems, RD LAP and data on new systems (such as the ones with newly installed GPS, which is a VERY new feature) are all encoded. Soo, breaking it is very difficult, if not near impossible, and it is also illegal to break the encryption.
                Radio DF'ing is almost impossible for many reasons. First, Most PDs operate io-n a repeater system. So, the signals "comes" from many places. Even if you listen to the repeaters "input", sometimes the units transmit on a portable with very little power, and sometimes with a mobile, with much higher power. This will make DF'ing very diffuclt. The next thing has to do with traingulation. IN order to get a somewhat accurate location, you need to triangulate the signal. That means you will need at least 3 receivers that receive the signal at the same time. That means all three must be within receiving distance of the transmitter. This would either take 3 fixed locations, with antennas mounted High, like 20 or 30 stories high, and don't forget, for a city or town, you will have to have overlapping coverage of the antennas. In a large city, you will need many receivers. Or, if you want to make them mobile, while possible, the problem will be having at least three receivers hear the transmitter. The next issue will be, to triangulate, you have to have the exact location of the receivers that are doing the trinagulation, and they all have to be on the exact smae time. This is usually occomplished with a connection to the atomic clock, or from a GPS signal. That is not to hard to accomplish, but it must be done cause even a difference of a second will mean VERY innacurate results because the triangulation requires calculation in the nano and milliseconds range.
                Then, once you overcome the trinagulation issues, the information MUST be sent somewhere, to accomplish the calculations to determine the transmitters location. Then, to top it off, police cars and officers are mobile, and they transmit often. In an hour, there will be so many transmissions from so many locations all over the city, that it will be impossible to know who is where and when. While most agencies do have som sort of ID on the radio signal, it is not easy to decode. There is no SW only decode of MDC ID, though there is some hardware out there that does allow serial output, and I have never seen a aftermarket decoder for MODAT.
                Then, to top it off, the FED is requiring agencies to migrate to Apco 25. Apco 25 is almost impossible to monitor, and many of the agencies are adding encryption to the voice channels to make monitoring impossible.
                At this point, it just aint worth it or possible.
                Michael
                  Michael
                  Wow, nice post. Well first off, like I was saying, triangulation would be a luxury feature; I don't feel it's necessary. After all, I know of only ONE radar detector which can give the direction that the radar is coming from (forget the model/brand at the moment, I researched these a few years back).
                  But as far as the rest: If you know the locations (via GPS, assuming you're driving around in a town you live in and have already mapped out) and relative output power of each repeater, you can "filter out" their portion of the signal, to some degree. Assume, for a moment, that there was some way that a cruiser could park next to a repeater, plug into it via a physical wire, and transmit/receive directly. If he did this, the repeater(s) would output in a certain pattern (intensity falling off like some constant * 1/r^2 from each repeater, ignoring reflections and other complications). With multiple repeaters, the intensity at one point would be a superposition of contributions from multiple repeaters.
                  Now, in reality, the cruiser doesn't do this, it has its own radio which transmits/receives directly (and is THEN amplified by repeaters, etc). So if you hear ANY radio activity on the police frequency, and you know the locations and relative strengths of the repeaters, you can generate (using a computer) the intensity you should measure if the cruiser was FAR away, so that its contribution was negligible. Now compare that to what your detector REALLY measures, and you can determine if the cruiser is somewhat near you.
                  If you record the "cruiser portion of the intensity" at a few points, and save the location of the points by stamping them with a GPS coordinate, you can get a vague idea of the cruiser's direction by watching whether the intensity increases or decreases as you drive around. You're just using discrete points to get an idea of the gradient of the intensity (or, cruiser-portion of the intensity). This is assuming his signal is still being transmitted as you drive around, of course. But if you latch onto the data frequency, there should at least be a steady stream of ACK's. Like I said though, that's probably not a feature that is critical.
                  Does that sound plausible?
                    Now, in reality, the cruiser doesn't do this, it has its own radio which transmits/receives directly (and is THEN amplified by repeaters, etc). So if you here ANY radio activity on the police frequency, and you know the locations and relative strengths of the repeaters, you can generate (using a computer) the intensity you should measure if the cruiser was FAR away, so that its contribution was negligible. Now compare that to what your detector REALLY measures, and you can determine if the cruiser is somewhat near you.
                    I think you may not understand how radio systems work. Basic explanation is this,
                    A repeater listens on one frequency (called the input frequency) and whatever it hears, it automatically transmits on a different frequency, called the output frequency. The officers radios actually transmit and receive on the exact opposite of the repeater. So, the repeater listens on "channel A" and transmits on "channel B", but the officers radios transmit on "channel A" so the repeater hears it, and listens on "channel B" so the officers can hear the repeater on "channel B"
                    Also, the PD has MANY repeaters, too cover the area as completely as possible. This means there is overlap of the signal. Also, it will be IMPOSSIBLE for a receiver to know which repeater it is hearing, so it can't tell if repeater A is weak, or repeater B is weak. While that is a problem of some sorts, you could always listen to officers signal, on "channel A", however, if the officer is using a protable radio, they are not very strong while mobile are much more powerfull.
                    Now, remember, a mobile/portable transmits in ALL directions. ANd there will be multiple transmitters. You will never be able to accurately track the signals, and you will have no idea where they are cause they will all be moving, and you will be moving, Assuming a signal is 5 miles away (just assuming it can be determined to be 5 miles away), it is 5 miles in any direction. It just makes no sense to try. As you move, another signal will be 5 miles away, while the original might be 3 miles away. what about the original being 5 miles away, and then someone else tranmits 3 miles away, then the original transmits 4 miles away, so where are they now? ALso remember, that they can be 3 and 5 miles IN ANY DIRECTION. No amount of calculation power will be able to determine who is where when, and going where.
                    Michael
                      Well, I'll admit I don't know much about the specifics of police radios, but the idea I'm trying to use would (I think) work on a more basic principle that would apply to most any system.
                      Well, I do understand what you're saying. You're just going to get a SUM intensity from many repeaters, and there's not going to be a nice easy way of identifying how much each repeater contributed to each signal. That's why I was saying you'd have to know the positions of the receivers w/ GPS (and your own position), so you could *calculate* what those repeaters *should* put out. Then add all of those together. If your real receiver measures intensity MORE than this by a non-negligible amount, that's the cruiser portion.
                      And I think you are correct, I'm assuming that the repeater is putting out the signal in the same band as the cruisers, but that actually complicates the problem. It's simpler if the cruisers are the *only* ones transmitting on "channel A". A couple questions that maybe you could explain, as I don't know much about police radio systems:
                      - If the cruisers transmit only on "channel A", and listen only to "channel B", is there an automatic failsafe mode if all the repeaters suddenly die, or a couple cruisers have to chase someone into some rural area with no repeaters? ie, a way for them to listen on channel A or transmit on channel B?
                      - Is there a provision for multiple-repeating? ie, cruiser sends a signal on "channel A", receiver boosts the signal and transmits on "channel B", then another receiver listens and re-boosts?
                      If this is the case, as I hinted at above, the problem becomes infinitely easier, no GPS needed, no false alarms, etc. Yes, you have to differeniate between portable/mobile radios, but still! Let's say the mobile radios are 10 times more powerful than the portable radios. Now our unit picks up a signal. We have calibrated the system so that, if it was a portable radio, the signal looks like it is 2 miles away. If we now assume that the radio is a mobile radio, how far should we expect it to be:
                      Intensity = k_portable * 1 / (2 miles)^2
                      Intensity = k_mobile * 1 / (x miles)^2
                      = 10 k_portable * 1 / (x miles)^2
                      Solve for x.
                      k_portable / 4 = 10 * k_portable / x^2
                      x = Sqrt[40] = 6.3 miles
                      Not that big of a difference. We'd still want the detector to start beeping, probably.
                      Wait, it makes no sense to try what? Knowing that there is a cruiser in 5 miles (in any direction, unknown to us) is good enough for me. That's all I am told by my radar detector. I don't get told specifically *where* the cruiser is, just that he's somewhere close by.
                      Well, first look at the simpler case where there is one cruiser, and he isn't moving. There I think we both agree on a method you could use to find the direction between you and him (drive around in your car and watch the cruiser signal intensity change). That is assuming he's transmitting the same thing over time (which is probably valid if you look at the data frequency).
                      Now look at the case with two cruisers, also not moving. There, you'd notice that you can't perform a k * 1/r^2 fit on the intensity data you're getting. You'd then try a [ (k1) * 1/(r1)^2 + (k2) * 1/(r2)^2 ] fit. With enough data, you can use minimization of error techniques to fit the data, and find his position.
                      Now if they are moving, one thing you can do is just take your sample points faster. This means less distance between readings, hence less intensity change, hence a little error matters a lot more, and you have a more vague idea about the direction they are in.
                      In reality, what I would do is setup about 10-20 "scenarios" (1 cruiser not moving, 2 cruisers not moving, multiple cruisers moving, etc) and for each case, try to use a statistical technique to *force* the data to conform to each pattern. You use RMS error minimizing to do this, varying the free parameters (angle of cruiser relative to front of your car, if you'd like to picture it that way) until you get the least RMS error between your intensity-position data and the intensity predictions of your model. You feed in a bunch of GPS positions and intensities, lots of data... If the simplest model has a very large RMS error, and the "next complex" model in the line is a better fit, you can let the user know that there are probably two cruisers, etc.
                      Anyway, like I said earlier, all this (everything since the last quote) is really not necessary, just knowing "there is a cruiser 3-5 miles in any direction" is enough for me. Anything more than that, and it sounds like you're getting the detector to plan a get-away route for a bank robbery. I just want something to tell me when to drive a little more conservatively.
                        THat is incorrect. There is no sum intensity. All the repeaters transmit at the same time. They are all high power. They also overlap. Also, you must know that transmitter power does not sum in that way. In fact, they employ VERY sophisticated timing between the transmitters so that they do now cancel them selves out. THey must therefore be 180 degrees out of phase. This is what happens
                        There is always a "Talk a round" mode where the units can communicate with each other. This is on the repeater output frequency, so even if a unit is "using" the repeater, they can hear a person on the talk around frequency. However, the dispatcher CAN NOT hear that person, and neither will anyone who is far away fromt he unit be able to hear him.
                        Here is another thing. Repeaters are the boosters. They provide coverage thru improved hearing and transmitting. Most PDs link all the repeaters together. If you look above, each circle is a repeaters coverage, both hearing and transmitting coverage. They are all linked together, so that all of them transmit what one of them hears. There is no need, technically, to have a reboost of a handheld in a properly designed system. There are situations where PDs use an small in car repeater. That requires a 3rd channel. Basically, the officer carries a low power protable, transmits and receives on channel C, the car then repeates channel C to the repeater on channel B (the one the repeater listens to) and then the repeater acts normally. The car then hears on channel A, and repeats the message on channel C so the officer can hear it.
                        Solve for x.
                        The problem being that a portable putting out 5 watts has a range of a couple of miles, lets say, while a mobile can have a range of 50 or 75. Unfortunately, range is dependent on MANY factors, transmitter power, antenna, feedline loss, and Altitude, of both the transmitting unit AND the reciever. Someone on the 100 floor of a building can hear a unit 10 miles away, while someone using the same unit to receive, int he same situation, might not be able to hear him from 10 blocks away. So while it might be calibrated to "beep" on receiving a portable, since it must be just 10 or 20 blocks away, a mobile could be on the other side of city, and a reciever will hear it. So, it will beep when the mobile is FAR FAR away. it will be worthless. You would have to listen to the portable/mobiles frequency, because as I mentioned, the repeaters will provide the same amount of power/range no matter where the mobile or portable is transmitting from.
                          Here is the thing. Besides what I mentioned above, that a mobile could "trip" the receiver and beep when across town, you have to realize that a radar gun transmitts in a single direction. It is a foruces beam, unlike a mobile or portable which transmits omnidirectionally. Next, radar guns have limited power, ont he order of less then one watt, and radars operate in the GHZ range. Thier propogation is very small. Basically, the signal won't travel very far. But PDs operate in the VHF, UHF and Ultra UHF bands. They have better propogation properties. Here is what propogation means. In the GHZ range, 1 watt of power will go 1/2 mile, while at VHF, 1 watt will go 5 miles, UHF 4 miles and Ultra UHF 3.5 miles.(these are just illustrative, like I said, there are many factors to consider, but this assumes all things are equal, and, the mileage is just part of the idea, I have no idea exactly how far a signal will go with out testing)
                          Huh. Officers generally spend about 30 minutes a day transmitting, perhaps at most an hour in an 8 hour period. Most often, much less. There is no way to accurately "track" him because of this. I don't get what you mean by "which is probably valid if you look at the data frequency" What do you mean by data frequency. THough technically, if there was only one officer, and he continuoly transmitted, and you moved around, you might be able to get a relative area where here is, but it would take some time. And, if he moved, well, you would have to start all over.
                          Now look at the case of two cruisers not moving. There, you'd notice that you can't perform a k * 1/r^2 fit on the intensity data you're getting. You'd then try a [ (k1) * 1/(r1)^2 + (k2) * 1/(r2)^2 ] fit. With enough data, you can use minimization of error techniques to fit the data, and find his position.
                          Whos position. You have 2 signals, which are indistiguishable to the receiver and the calculations. And, they are not transmitting continuously, so the amount of data available per unit is very small.
                          Again, the added problem of getting data is difficult because they don't transmit that often, they move ,A was here, but is now there, and b is halfway between A and B, then A and B are in the same place, and then they switch places, but to the receiver, they are all 5 miles away from you. And, they don't transmit in every location, and sometimes they transmit while they are moving.
                          There IS no pattern. Officers do not follow a pattern.
                          HUH
                          Back to the beginning, the problem is that there is no way to accurately tell when a transmitter is that close because of the difference in mobile, and portable power, though I guess technically, if ALL you want to know is if there is a transmitter near by, you can make the receiver near deaf, so that it won't pick up strang signals as easily, but then weak signals will have to be on top of you to receiver, or let the receiver be as is, and just get false alarms when the po po are on the other side of town.
                          Michael
                            Originally posted by PandaInnovation
                            I haven't read this WHOLE thread, but here's something that ACTUALLY WORKS!
                            I have a VHF mobile radio in my truck. I have it set to receive 154.905MHz, which is the channel the the Cali Highway Patrol uses for their mobile extenders. These extenders are in the CHP cars and they allow for the officer's handpak to work with the lowband (42MHz) system. Here's a diagram:
                            Handpak ---> Moble Extender ---> Lowband Mobile Radio in CHP Car ---> Dispatach
                            These mobile repeaters (MR) are really low power, perhaps 100-200mW or so. We know the handpaks are low power too (so they only work so far from a CHP vehicle).
                            Basically, if you have a radio listening on 154.905 and there is a CHP unit close enough to you (less than a mile??), you'll hear whatever is coming across the radio system. This is not just limited to that particular officer's transmissions as everything is rebroadcasted out the MR.
                            Great tool for roadtrips down Hwy 5!!
                            The CHPs mobile repeater/extender is a very unique situation. Very few PDs use extenders.
                            Michael
                              Michael
                              Trasnsmission wasn't the idea...i woudl tell you what a friend proposed but that would be bad... Then gas prices went up to $3 and it just wasn't cost effective to speed anymore.. Then again, they sped more than i did, so it doesn't bother me too much. And your last paragraph is the second reason why we didn't bother with my friend's suggestions
                              All in all, there are easier ways of avioding the polie...and sometimes the old tricks are the best ones (like making sure someone's going a lot faster than you per 12 mile stretch at night on the interstate)
                              THE GF THEME
                              Genesis has speed
                              Genesis has class
                              Genesis sent money
                              before your a__;)
