BMW E36 : OBD 1 - Diagnostic Tool, anyone speaks German ?
  • BMW E36 : OBD 1 - Diagnostic Tool, anyone speaks German ?
    Hi All,
    When doing some 'research' aka googling I stumbled on this :
    http://fileshare.eshop.bg/download.php?fileid=3721
    At the first glance it looks like a DIY to construct a
    Diagnose / Odometer reset interface for the non-OBD 2
    version of the E-36 but it is in German :-(
    Is there anyone that speaks the language that could provide
    a translation to English so that we can 'examine' this further?
    I'm especially wondering if it only can reset the data for the
    odometer or if it can read out mere data from the ECU, and
    whether that data could be put to use ....
    The pixels of my 1994 320i (E36) Check control (aka 11 button
    OBD) are dying so it would be very nice if I could lose the
    entire thing and use the lilliput to display the data.
    Sincerely,
    Jurgen
    Are you sure the Check Control isn't just a bulb blown. they are easily replaced?
    Don't think you can display the same data as it displays easily on a computer, there are lots of things connected to it.
    Jurgen - sounds German, but you can't translate the German to English?
    Here is my best effort.
    Bear in mind you will then need some software to understand what is being sent.
      Google has a free translating web site:
      http://www.google.com/language_tools
        Hey Jpuype,
        Maybe I can help you. I don't know much about cars, but I can try myself (if you already didn't translate it).
        Greetings
        Jok3r
          dang, i could make that hardware.. but where to find the software?
          I wonder if you can keep it connected all the time with the car running
          New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
          SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
            Your guess is correct. It's an E36 odometer controller via the OBD interface
            Enforcer's tranlation seems to be quite OK.
              Hi all,
              The software appears to only allow the changing of the odometer. The hardware may well allow for other information to be read, but without the serial commands to do so, it would be an uphill battle.
              I did locate the software used with this hardware, but I am not posting the link because, as noted in the German language document, changing the odometer is illegal. If you really need the software, it can be found on the same site as the schematic.
              pb
