Centrafuse, TPMS 2.1.0.9 and Vista
  • Centrafuse, TPMS 2.1.0.9 and Vista
    ...don't get along well together...lol This is Vista, not SP1, although I did install the SP1 upgrade, and issues with CF were worse in my case.
    The plugin installs fine, and works fine, reading the data properly.
    But after some time, CF becomes unresponsive. Not technically 'unresponsive' (as in the task manager), but inputs to volume, etc don't do anything...right away. After some seconds pass (30 or 40), the input is registered and executed however. CF continues functioning as far as playing media/NAV/etc...
    When CF is restarted, more often than not, it restarts in this non-responsive state immediately...until the plugin is removed.
    After I install the plugin, I configure the wheel assignments and change BAR to PSI and set my pressure ranges...prior to changing these settings, CF seems fine, however it might be a coinsidence, as it only take a minute to change.
    I will however, retest without any changes to the options, in case the issue is caused by maybe the PSI conversion or the tire reassignments, just to be sure...
    I'll report back later today...
    Is there a more recent CF plugin available for testing?
    Here is the last log file from the TPMS....I see errors, but that's all I know. Anyone care to have a look?
    Thanks...
    40:59:30> Click_Action(): CurrValue=2
    41:04:70> Click_Action(): CurrValue=1
    41:04:90> Click_Action(): CurrValue=2
    41:05:10> Click_Action(): CurrValue=3
    41:05:43> Click_Action(): CurrValue=4
    12:56:06> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    at System.IO.FileStream.EndWrite(IAsyncResult asyncResult)
    at System.IO.FileStream.FlushWrite(Boolean calledFromFinalizer)
    at System.IO.FileStream.Dispose(Boolean disposing)
    at System.IO.Stream.Close()
    at tpms.HIDDevice.Dispose(Boolean bDisposing)
    at tpms.HIDDevice.Dispose()
    at tpms.HIDDevice.Write(OutputReport oOutRep)
    at tpms.TpmsDevice.WriteReport(TpmsOutputReport outputReport)
    at tpms.tpms.GetDataFromDevice()(): A device attached to the system is not functioning.<CR><LF>
    54:33:78> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    54:34:78> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    54:56:33> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    at System.IO.FileStream.BeginWriteCore(Byte[] bytes, Int32 offset, Int32 numBytes, AsyncCallback userCallback, Object stateObject)
    at tpms.tpms.GetDataFromDevice()(): Unable to find the specified file.
    56:03:94> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    19:14:80> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    19:17:57> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    19:25:63> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    19:31:52> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    19:39:30> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    19:55:39> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    20:02:64> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    20:10:06> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    22:55:40> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    23:17:72> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    23:55:61> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    04:50:83> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    04:51:88> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    05:17:66> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    05:44:16> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    06:44:96> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    08:28:66> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    09:28:82> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    14:30:37> Click_Action(): CurrValue=2
    14:33:46> Click_Action(): CurrValue=1
    14:33:65> Click_Action(): CurrValue=2
    14:33:84> Click_Action(): CurrValue=3
    14:34:04> Click_Action(): CurrValue=4
    24:19:08> Click_Action(): CurrValue=2
    24:20:40> Click_Action(): CurrValue=1
    24:20:58> Click_Action(): CurrValue=2
    24:20:75> Click_Action(): CurrValue=3
    24:20:93> Click_Action(): CurrValue=4
    17:25:23> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    18:24:93> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    19:32:73> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    19:52:79> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    56:26:95> loadSettings(): START
    56:26:96> loadSettings(): END
    56:26:97> LoadValues(): START
    56:26:97> CF_localskinsetup(): START
    56:27:07> CF_localskinsetup(): END
    56:27:07> CF_pluginInit(): END
    56:32:67> TPMS_Loaded(): START
    56:32:68> TPMS_Loaded(): END
    56:33:72> GetDataFromDevice(): START
    56:34:60> GetDataFromDevice(): END
    56:35:64> GetDataFromDevice(): START
    56:36:17> GetDataFromDevice(): END
    56:37:19> GetDataFromDevice(): START
    56:37:74> GetDataFromDevice(): END
    56:38:73> GetDataFromDevice(): START
    56:39:27> GetDataFromDevice(): END
    56:40:27> GetDataFromDevice(): START
    56:40:89> GetDataFromDevice(): END
    56:41:04> Btn_Click(): START
    56:41:04> Btn_Click(): EMD
    56:41:88> GetDataFromDevice(): START
    56:42:39> GetDataFromDevice(): END
    56:43:39> GetDataFromDevice(): START
    56:43:90> GetDataFromDevice(): END
    56:44:91> GetDataFromDevice(): START
    56:45:43> GetDataFromDevice(): END
    56:46:65> GetDataFromDevice(): START
    56:46:97> GetDataFromDevice(): END
    56:47:97> GetDataFromDevice(): START
    56:48:49> GetDataFromDevice(): END
    56:49:50> GetDataFromDevice(): START
    56:49:92> GetDataFromDevice(): END
    56:50:95> GetDataFromDevice(): START
    56:51:46> GetDataFromDevice(): END
    56:52:47> GetDataFromDevice(): START
    56:52:99> GetDataFromDevice(): END
    56:54:05> GetDataFromDevice(): START
    56:54:57> GetDataFromDevice(): END
    56:55:26> CF_pluginInit(): END
    56:55:27> CF_localskinsetup(): START
    56:55:41> loadSettings(): START
    56:55:41> loadSettings(): END
    56:55:41> CF_localskinsetup(): END
    56:55:41> CF_pluginInit(): END
    56:55:66> GetDataFromDevice(): START
    56:56:18> GetDataFromDevice(): END
    56:57:17> GetDataFromDevice(): START
    56:57:69> GetDataFromDevice(): END
    56:58:69> GetDataFromDevice(): START
    56:59:21> GetDataFromDevice(): END
    57:00:20> GetDataFromDevice(): START
    57:00:72> GetDataFromDevice(): END
    57:01:72> GetDataFromDevice(): START
    57:02:23> GetDataFromDevice(): END
    57:03:25> GetDataFromDevice(): START
    57:03:77> GetDataFromDevice(): END
    57:04:72> Setup_Click(): START
    57:04:72> Setup_Click(): END
    57:04:79> GetDataFromDevice(): START
    57:05:31> GetDataFromDevice(): END
    57:06:31> GetDataFromDevice(): START
    57:06:83> GetDataFromDevice(): END
    57:07:82> GetDataFromDevice(): START
    57:08:34> GetDataFromDevice(): END
    57:08:35> Setup_Click(): START
    57:08:35> CF_localskinsetup(): START
    57:08:56> loadSettings(): START
    57:08:57> loadSettings(): END
    57:08:57> CF_localskinsetup(): END
    57:08:57> Setup_Click(): END
    57:09:35> GetDataFromDevice(): START
    57:09:87> GetDataFromDevice(): END
    57:10:86> GetDataFromDevice(): START
    57:11:37> GetDataFromDevice(): END
    57:12:25> Setup_Click(): START
    57:12:25> Setup_Click(): END
    57:12:45> GetDataFromDevice(): START
    57:12:87> GetDataFromDevice(): END
    57:13:86> GetDataFromDevice(): START
    57:14:37> GetDataFromDevice(): END
    57:15:37> GetDataFromDevice(): START
    57:15:89> GetDataFromDevice(): END
    57:15:90> Setup_Click(): START
    57:15:90> GetNewPressure(): START
    57:16:90> GetDataFromDevice(): START
    57:17:42> GetDataFromDevice(): END
    57:18:42> GetDataFromDevice(): START
    57:18:94> GetDataFromDevice(): END
    57:19:95> GetDataFromDevice(): START
    57:20:47> GetDataFromDevice(): END
    57:21:47> GetDataFromDevice(): START
    57:21:99> GetDataFromDevice(): END
    57:22:08> Setup_Click(): END
    57:23:00> GetDataFromDevice(): START
    57:23:52> GetDataFromDevice(): END
    57:24:29> Setup_Click(): START
    57:24:30> GetNewPressure(): START
    57:24:51> GetDataFromDevice(): START
    57:25:04> GetDataFromDevice(): END
    57:26:03> GetDataFromDevice(): START
    57:26:55> GetDataFromDevice(): END
    57:27:62> Setup_Click(): END
    57:27:65> GetDataFromDevice(): START
    57:28:17> GetDataFromDevice(): END
    57:29:18> GetDataFromDevice(): START
    57:29:70> GetDataFromDevice(): END
    57:30:69> Setup_Click(): START
    57:30:70> GetNewPressure(): START
    57:30:85> GetDataFromDevice(): START
    57:31:37> GetDataFromDevice(): END
    57:32:37> GetDataFromDevice(): START
    57:32:89> GetDataFromDevice(): END
    57:33:89> GetDataFromDevice(): START
    57:34:41> GetDataFromDevice(): END
    57:34:42> Setup_Click(): END
    57:35:41> GetDataFromDevice(): START
    57:35:93> GetDataFromDevice(): END
    57:36:40> Setup_Click(): START
    57:36:40> GetNewPressure(): START
    57:36:92> GetDataFromDevice(): START
    57:37:43> GetDataFromDevice(): END
    57:38:45> GetDataFromDevice(): START
    57:38:97> GetDataFromDevice(): END
    57:39:97> GetDataFromDevice(): START
    57:40:48> GetDataFromDevice(): END
    57:41:48> GetDataFromDevice(): START
    57:42:01> GetDataFromDevice(): END
    57:42:02> Setup_Click(): END
    57:43:01> GetDataFromDevice(): START
    57:43:53> GetDataFromDevice(): END
    57:44:53> GetDataFromDevice(): START
    57:45:05> GetDataFromDevice(): END
    57:46:05> GetDataFromDevice(): START
    57:46:56> GetDataFromDevice(): END
    57:47:58> GetDataFromDevice(): START
    57:48:11> GetDataFromDevice(): END
    57:48:11> Setup_Click(): START
    57:49:11> GetDataFromDevice(): START
    57:49:63> GetDataFromDevice(): END
    57:49:65> Setup_Click(): END
    24:18:62> Click_Action(): CurrValue=2
    24:21:68> Click_Action(): CurrValue=1
    24:21:85> Click_Action(): CurrValue=2
    24:22:04> Click_Action(): CurrValue=3
    24:22:23> Click_Action(): CurrValue=4
    28:00:10> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    at tpms.tpms.GetDataFromDevice()(): The parameter is incorrect.<CR><LF>
    42:02:30> Click_Action(): CurrValue=2
    42:05:51> Click_Action(): CurrValue=1
    42:05:68> Click_Action(): CurrValue=2
    42:05:84> Click_Action(): CurrValue=3
    42:06:02> Click_Action(): CurrValue=4
    58:15:03> Click_Action(): CurrValue=5
    58:24:80> Click_Action(): CurrValue=2
    58:27:26> Click_Action(): CurrValue=1
    58:27:44> Click_Action(): CurrValue=2
    58:27:63> Click_Action(): CurrValue=3
    58:27:82> Click_Action(): CurrValue=4
    00:59:02> at tpms.tpms.GetDataFromDevice()(): Object reference not set to an instance of an object.
    01:21:64> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    01:28:99> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    01:36:73> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    01:44:02> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    01:51:53> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    01:59:02> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    02:06:64> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    02:14:05> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    02:21:65> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    02:29:28> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    02:36:66> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    02:44:02> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    02:51:41> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    02:59:10> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    03:06:48> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    03:14:30> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    03:21:73> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    03:29:32> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    03:36:71> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    03:44:32> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    03:51:67> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    03:58:99> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    04:06:69> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    04:14:11> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    04:21:54> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    04:29:04> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    04:36:94> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    04:44:31> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    04:51:50> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    04:59:39> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    05:07:04> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    05:14:04> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    05:21:46> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    05:29:15> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    05:36:64> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    05:44:11> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    05:51:54> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    05:59:16> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    06:06:56> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    06:14:01> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    06:21:49> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    06:29:34> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
      This seems prevalent, however, I only have 3 working sensors right now, so maybe that's what the log is saying?
      "A device attached to the system is not functioning."
        bump...?
          I just replaced my 'bad' sensor with a brand new replacement from Portal Media...and it's not being 'read' by RRTMS either!
          Is there maybe something wrong with RRTMS and the front/right sensor programing?
            Okay, my fault...I forgot to change the sensor assignment to 'sensor 5' for that wheel...it's programmed now, BUT...
            I did a master reset on the board, and began relearning all the sensors. All of them are 'learned' now except my right rear!!
            This was the sensor that came detached from the stem and spent some time tumbling in my wheel...
            Is it destroyed?? It didn't look damaged...aren't the electronics expoxied? Think the battery came loose or something?
            Can the system be used with 2 'spare' sensors, if I have to replace another one?
              Sorry for leaving you hanging there. I know I answered this for you in an email but better to let everyone else know as well. Spare sensors and the sensors you get in your kit are identical. If you were to damage any one of your sensors you can replace it with a spare and relearn that particular sensor. The sensor is one solid piece with potting on the inside and the battery cannot be replaced, after about 5 years you will have to replace the actual sensors.
                Thanks Alok...
                I'm due for a set of tires shortly, so I might hit you up on yet another sensor...
                I'll be in touch.
                However, with me stuck with Vista, I can't make use of the current plugin
                  Running XP SP3 now, and still getting the same random CF lockups as I did in Vista with the latest plugin...
                    Hmm, I am quite interested to know what is going on in particular with your system. There are now hundreds of users that are using this plug-in and device who have no issues at all. I know its kind of a stupid question but have you fully updated Centrafuse? I was having some lock up issues with the previous version of CF but not with the latest version.
                      Running .1331 with update 2...
                      BTW, I'm running the 2.1.0.9 (or is it 2.1.0.8?) plugin. I tried the original release, and it did the same thing...
                      This is a clean install of XP...had the exact same issue with my previous Vista install. So it's not an OS issue, like I previously thought.
                      I'm guessing it's because maybe 1 of the sensors isn't programmed? We'll know for sure when the new spare sensor arrives and I get it installed...
                        Did you do the dll update? Wolfgang has it posted in the thread a post or two below the OP. You have to cut and paste the new dll/language folder into the tpms folder in your CF directory. I don't think having one sensor programmed would cause this issue, it should not make a difference how many sensors are programmed in.
                          Okay...downloading now...
                          I never guessed to look back on page 1 for updates. I figured they would of came in order, or posted in the download section
                          Thanks Alok...
                          I'll re-test with the 3 sensors I have running now. I got the new sensor in the mail last week...thanks again.
                          It'll have to wait til I can afford tires for me to install it!
                            Hi Alok
                            Well finally the system is UP n working as i have got a new screen but am not able to get all the sensors to LEARN....
                            i could only manage to get 2 to learn....So did try to do a Master reset... Still no luck
                            can you pls help as how do i go about it
                            Capt Vikas Uberoi
                            Commell LV-677 DC 6 x 6" Mother Board
                            2.6 GHz; 1 Gb Ram
                            120 Gb Laptop HD
                            7" InDash Xenarc MTD - X7000 Screen
                            Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
                            Parrot MK 6000 & iPhone
                            Re done the carputer...Into the Glove Box !!
                              Hello Vicky,
                              The problem you are having is due to the sensors going into storage mode since they have have been in little or no pressure for quite some time. If you raise the PSI over 15 and then back down below 5 this should 'wake' the sensors. Then proceed with the learning procedure as normal. If you still have issues please let me know and we can try to figure out what is going on.
