Problem with lilliput software
  • Problem with lilliput software
    I have a lilliiput 7'' in dash touch screen. The monitors works fine but I have a problem with a sound when touching the panel. THe sound can not be turned off, I have tried advanced settings but it seems that it is not working, can not even change the pitch or anything, when I uncheck sound or it is checked there is no difference. For me it sounds like a software lilliput problem..any ideas? how to turn this off?
    thanks
    Media Engine Audi Skin running on Compaq Evo 1,6Ghz 512RAM 200HDD,Tv card, connected to lilliput 7'' touch screen
    1 - If you're not using the latest touchkit drivers, I suggest doing so: http://www.eeti.com.tw/web20/eg/drivers.htm
    2 - There is an option in there to turn off the beep on press option in the touchkit control panel. Is this where you're turning off the beep on press?
    How about the Wiki?
      thanks for advice, I have changed the drivers and it works fine now
