Powermate sensitivity
  • Powermate sensitivity
    I'm trying to get a Powermate to play nice in my install. Is there any way to lower the sensitivity on the thing? Right now it seems to raise/lower the volume in 5% or bigger increments and that is just too much. I have a lot of juice in my system and at 5% volume I can't even talk to someone comfortably in the car without shouting over the music.
    I'd just like to have a bit more control over the precision of my volume in Streetdeck.
    Are you using the new driver or the old?
    I had the same problem with adjustments at the lower end and conversation in the car. Here's what I found out:
    I downloaded the new "improved" driver from the powermate site and it would only adjust in 2% increments at the lowest.
    a re-install of the original drivers gave me back my 1% adjustments and all was fine in the world again.
    Try or some other such site to get the older driver as griffin doesn't seem to have it available anymore..............
    Leonardo Da Vinci
