Which rear view camera, between these two?
  • Which rear view camera, between these two?
    Can anyone comment on which of these two cameras may be the best in respect to specifications or any others equally appropriate. I would like to use one for a rear view camera and also possibly a front view cam. I will be accommodating these requirements via a direct Xenarc monitor connection and USB capture adapter.
    Im just interested in anyones view on these cameras in respect to their use or differences such as the Minimum Illumination, Built-in Lens, Lens Angle and other differences?
    Rectangular Bracket Mounted Camera
    With Audio and IR
    Image Device: SHARP
    TV System: PAL / NTSC
    Effective Pixels: 512 x 582 pixels / 512 x 492 pixels
    Sensing Area: 4.9mm x 3.7mm
    Scanning System: 2:1Interlace
    Sync. System: Internal
    Resolution: 420TV lines
    Horizontal Sync. Frequency: 15.625KHz / 15.734KHz
    Vertical Sync. Frequency: 50Hz / 60Hz
    Minimum Illumination: 0 Lux/F1.2 with IR
    Microphone: Optional
    Video Output: 1.0vp-p, 75Ohm
    Gamma Consumption: 0.45
    AGC: Auto
    S/N Ratio: Better than 48dB
    White Balance: Auto
    Electronic Shutter: 1/60(NTSC) / 1/50(PAL) ~ 1/10,000 Seconds
    BLC: Auto
    Current Consumption: Max. 300mA
    Power Supply: DC12V
    Operating Temperature: -20C~70C , RH95% MAX
    Storage Temperature: -40C~80C,RH95% MAX
    Lens: f=3.6mm / F = 2.0
    Lens Angle: 92
    Yan Laboratory Electric Science & Technology (USA) LLC
    CCD Color EXTRA Heavy Duty Commercial Grade Night Vision Infrared Wide View Angle Vehicle Rear View Backup Camera
    Model Number: CW134086CI, CW134086CAI (audio model)
    System Specifications:
    Image Sensor 1/3" SHARP CCD Sensor
    Horizontal Resolution 420 TV Lines
    Horizontal Sync Frequency 15,734 kHz
    Vertical Sync Frequency 60 Hz
    Effective Pixels 519(H) x 492(V)
    Minimum Illumination 0 LUX (w/ LEDs on) / F:2.0
    Sensing Area 4.9mm x 3.7mm
    Number of IR LEDs 28
    Video Out Signal 1.0 Vp-p 75 ohm
    IR Distance Approx. 35 - 50 feet (10 - 15 meters)
    AGC Auto
    S/N Ratio Better than 48dB
    Electronic Shutter 1/60 - 1/10,000 second
    Weight Approx. 18.5 oz (525 g)
    Sync System Internal
    Built-in Lens f=2.8mm / F=2.0
    Current Consumption Max 400mA
    BLC Auto
    Gamma Consumption 0.45
    Power Supply DC 12V
    White Balance Auto
    TV System NTSC
    Operating Temperature -4F - 158F (-20C - 70C) / RH 95% Max Storage Temperature -40F - 176F (-40C - 80C) / RH 95% Max
    Cable Input/Output (2 Sockets) Yellow Socket - RCA Video Output,
    Black (or Red) Socket - DC Power Input
    Lens Angel Wide View Angel 120
