Touch screen interference
  • Touch screen interference
    hey all,
    i've just put my laptop and touch screen in, but i am getting all sorts of interference on the monitor. the picture comes through and the touch screen still functions.. but there are lines moving up the screen etc.. but only when the laptop is running of the dc power supply. when i unplug the laptop from the cigarette lighter and have it on batteries the screen works fine.... also i tried using an external battery to run them and found that if i power both the laptop and the screen of the external battery theres interference, but if i power 1 off the car and one off the battery it works fine.... any ideas?
    _-_-_-_-_-_-_-_-_
    Holden FTW!
    Carpc Mk 1
    Carpc Mk 2 (in Progress)
    I have the same problem. Did you figure it out?
      yeh i fixed it... the problem was the dc power supply... i switched over to using an inverter and the ac power supply that came with the laptop and it all works good now
      _-_-_-_-_-_-_-_-_
      Holden FTW!
      Carpc Mk 1
        Bringing an old thread back to life............
        Wouldn't the inverter draw more power/current than the DC/DC supply? Thus putting more strain on the engine/alternator/car battery?
          yes but that isnt the issue. Audio interference and a bunch of other nasty things are introduced with an inverter. You just need to properly wire things with good sized cables and space the cables correctly and interference wont be an issue.
          1.9in x 2.9in -- 47mm x 73mm
            Interesting.
            I've got the "Lines" on my Lilliput at the moment, and the too go away when i use the AC/DC adapter off the house supply. I'm against using an iverter basically because I see it as a useless increase in voltage just to come back down to 12V again. I've been advised to bypass the adapter and earth the -ve terminal off the adapter pin to the cars ground as opposed to going back through the adapter. Would this work do you think?
              It *might* work, but the adaptor is already grounded to something and if you are using, say, the cigarette lighter for the power, then it is already grounded to the car's ground.
              One solution that can sometimes help is to run the screen off of the DC-DC power supply for the computer. It regulates the power and that may be the cause of the wavy lines.
              Also, I've heard that poor quality cables can be part of the issue. If you are using an extension to the Lilli cable, try a different one.
              Want to:
                update
                hey guys,
                if you look at my project log, you can see that i got rid of the laptop, and replaced it with a proper pc. i came to this conclusion: while a laptop is good because its small and designed to be power efficient, you are always going to have issues with sound and picture interference in a car environment because all the components are integrated and so close together. with the new pc setup, running of a m4-atx, the interference came back a little, but no where near as bad as before, not really noticable... i have come to the conclusion that its mainly due to the tiny size of the ground cable that comes out of the touch screen. i plan to dissasemble my screen in the near future and improve all the grounding, hopefully this will remove it completely. i imagine the inveter worked as a fix as it didnt allow the screen to ground back through the pc.
                _-_-_-_-_-_-_-_-_
                Holden FTW!
                Carpc Mk 1
                  I was having the same issue. Noise in the screen when laptop power plugged in and would go away completely if laptop was running on batteries. I tried 3 different laptop power supplies, noise filters etc but to no avail.
                  Then I tried grounding the laptop's chassis. Voila!!! perfect screen with no noise!!!
                  To ground the laptop I connected a thin ground wire to the metal surround of the parallel port. Even connecting it to the screw terminals of the vga port worked for me.
