PS3 wireless keypad attatchment
  • PS3 wireless keypad attatchment
    http://www.engadget.com/2008/08/20/s...t-for-the-ps3/
    ..."and can be paired with phones and other gadgets via Bluetooth."
    hopefully this is true
    Personally, for a carpc I would never get a keyboard that I cannot ctrl + alt +del with...
      I can verify that it does work with a PC just fine. It even has a "touchpad" feature that lets you control the mouse of windows, left click and right click.
      I'm running the WIDCOMM Bluetooth stack under Windows XP SP2, and it paired up just fine. I cant figure how to configure the touchpad part of the PS3 Keypad in Windows. If you could adjust the sensitivity some how, then you could make it perfect. The problem is the touchpad part (which is more like a proximity sensor underneath the qwerty keypad, all you do is run your finger along the keys just like a touchpad and it moves the mouse) is that even when my hands are no where near the keypad itself, the mouse "jitters" by itself. And granted, its not as precise as you would think, I think it works just fine considering.
      I have yet to test it in the car on a smaller screen though...
      Carputer Progress
      [||||||||||] 100%
      Finally Installed!!
      Everything is in the car and working.
      I painted the cilpboard mount and it looks good.
      Shutdown/Startup is working excellent!
      View My Progress Here
        Sony would sell more of these if they copied the MS XBOX keypad location AND placed the ctrl, alt, delete keys on it.
        Using this device is like trying to type on a Blackberry with the keyboard placed above the display.
        Check out my CARPC: Project Diamond Plate
        Quick Reference:
        CPU Electrical Specs
        Power Supply Calculator
        Video Connections for newbies
        Temperature Converter
        Voltage Calculator
          like this keyboard?
          http://usb.brando.com.hk/prod_detail...015&cat_id=034
            Thats nice. But for $47, Damn
              Originally posted by we87 View Post
              I can verify that it does work with a PC just fine. It even has a "touchpad" feature that lets you control the mouse of windows, left click and right click. I'm running the WIDCOMM Bluetooth stack under Windows XP SP2, and it paired up just fine.
              Do I need that whole joystick/pad/thingy to connect this or is it just a battery (for the power) and the keyboard can be used stand-alone?
              http://daevid.com/gfx/tC
              Infill G4. StreetDeck.
              Installed 09/17/07
                Originally posted by tikoro View Post
                That looks great, except how is battery life. I'd be afraid the batteries would be drained every time I went to use it b/c something in my glovebox held down a button all night or something.
                Also, how are they actual keys and their connections? I ask, because I have a tiny keyboard and it seems that 1/3 keys don't fire as I type naturally. I am always having to go back and correct, or hunt & peck so I can visually watch the screen and verify the key triggered. It sucks!
                Installed 09/17/07
                  Here's a wired USB one for $25.
                    Originally posted by bemenaker View Post
                    Right, but not illuminated. I already looked through their site and even wrote them about this. Awaiting their reply.
                    Installed 09/17/07
