got a problem, please check the pictures i added 7"lilliput
  • got a problem, please check the pictures i added 7"lilliput
    well im have no degree or something in english and dont have a idea how its called in english
    i have installed my carpc and the touchscreen its a lilliput 7"
    now i have connected it to the battery got 2 battery's both do the same btw
    and it works good the computer starts , gives me an image etc
    but i see this very annoying stripes
    ive tested many things, no extension cable between the screen and computer, different power sources , nothing else on because i have xenon lights and those give allot of interferance but thats alos not the problem, powered without the amp's head unit etc
    still getting those annoying stripes
    does anybody has the same problem or has a sollution
    thanks allot
    go to my new website:
    http://corsa-t-design.19division.nl
    Looks like you have a bad ground for the screen. I have seen that before and a bad ground was the issue. Where are you getting the ground/power for the screen?
    I would suggest that you get both power/ground from the computer's power supply.
      thanks for the tip, i got the screen connected to the battery in the front of the car
      and the computer in the back of the car
      ill give it a try , also opened the case and post a pic of it here maybe someone can see if something is wrong like a wire against something that isnt supposed to be
        Definitely don't connected straight to the battery. Get both the ground/power from the computer's power supply.
          thanks fabworks, it sounds also logic what u say
          i just tested the carputer on my starter kit
          powered on that battery it doesnt give any stripe on the screen with the screen on a different battery btw
          tomorrow when im done working i will test it on the power source of the computer self, got also an email from the guy i bought the carpc from
          he said also something similar what u said
          i will keep u guys posted
          thanks again
            Are you using a M4 or M2 power supply??
              its the m2
              here some pictures of my computer
              has the m2 not enough to also power the lilliput screen ?
                The M4 and M2, in my opinion, are not worth the money...
                I had serious issues with a M4 (screen problems like yours AND no sound out of the sound cards)...I tried 2 seperate M4's...same problems.
                Bought an OPUS and called it a day
                  I have been using the M1 and M2 for years without any issues. The M2 can handle the screen easily, I have it hooked up that way with no problems.
                  No sound for sound card would not be an issue of the power supply.
                    Yeah, it is! Obviously the M4 couldn't power a pair of Xonar's...
                    It doesn't supply adaquate power to the PCI bus.
                    I tried TWO different M4's on TWO different motherboards! Nothing but static out of the sound cards...and corrupt display.
                    As soon as I hooked up the OPUS, no more issues...yeah, that doesn't sound like a power supply issue to me!
                    And I didn't even have the screen powered off the M4's...just the bare minimum.
                    I'm sure lot's of people don't have issues with the mini-box PSU...
                    But lots of people do have problems as well...
                    Anyways...
                    You might try powering the screen off the M2, and make sure the screen and M2 have a common ground point...preferably NOT a chassis ground, but straight from the battery...
                      thanks for the reply's but i just connected the screen on the m2 and it was still the same
                      i used power from a connector to put in a harddisk or dvd player
                      i dont have any idea whats the prob, because when i power the computer on a battery thats not connected to the whole system , i mean the audio/car ignition / etc
                      then i dont see any stripes, nothing its perfect even when my engine is started
                      so i think maybe it something has to do with the m2 or the fans could that be possible ?
                      i hope its a bit clear how i try to explain it
                        Where is the ground to the M2 hooked up? Chassis?
                          Are u hooking up both the ground/power of the screen to the M2 or just the power?
                          Where is the M2 ground connected to?
                            the ground was made on the frame of the car ,
                            now i made the ground of the m2 to the battery itself
                            and the ground of the screen is on the m2
                            it has improved indeed but the stripes are still there
                            i will try to put a filter between it or something hopefully is gone then
                            thanks for the help again
                              Also check if you have anything with sever radio or magnetic interference near the screen. Sometimes just the frame of the vehicle can bring magnetic interference to the screen.
                              http://www.mp3car.com/vbulletin/work...150-carpc.html
