So what do y'all use?
  • So what do y'all use?
    So let's get some input from the guys who've got working projects in their cars...
    What do you use to control your player while you're driving?
    Got any pics of your control interface?
    I had a numeric keypad mounted in place of my ash tray initially, but Winamp/Zhender's plugin had a bunch of problems with the Num Lock key and Del key, so I'm going to try some form of iR remote this time around.
    irman mounted by the steering column and a credit card sized remote. works nicely for my mp3 only character setup!
    Car: 1999 Dark Green Mustang GT Coupe
    Audio: Alpine HU, JL 6ch Amp, JL Stealthbox and XR series components.
    Player: Empeg for now; something custom later.
    www.neotechpc.com - Custom built laptops!
      i just use a irman with a mouse if i need it.. I usually don't. I also have a gamepad to play my NES emu
      '98 Explorer Sport
      80% done
        well my own IR receiver works wonders ..... does about everything
        you can find the pictures here
        www.mastero.tk (photo section)
        mastero
          Hey CrazyLittle, is your keypad programmable? can you set like one of the buttons to be "alt" and the other to be "tab", or perhaps one button the be "alt+tab" I was just thinking here. you know, when you hit alt-tab in windows it brings up a little window of every program running. and lifting up the tab, and leaving the alt down, and then hitting tab, you can select a program to be brought to the foreground, and be the active program.
          So... I was thinking, heres a question for you folks who do have programmable buttons... Can I make one button alt-tab-tab ? I mean, if I had one button that could let me toggle between the mp3 player and the gps that would be great.
          1995 SL stock
          Working On: GMAT
          Given Up On: Custom motorized lcd
            you can probably use girder to set that up easily. www.girder.nl
            System: AMD Duron 1200+ , 512 MB ram , usb sb mp3+ , Tview 7" touchscreen , M1-ATX PSU , Slot Load iMac DVD-Rom , 40 GB laptop HDD, netgear USB 802.11g
            Progress: Installation: 90% Dash fabrication: 80%
            Parts Needed: USB GPS
              I made a remarkable discovery when I learned that the cheap as dirt creative remote recievers work with my onkyo remote controls. My reciever has multi functions for cd, dvd, and cassette deck.. so in my house I've been using it to control various applications, plus my reciever, all from one remote. I'm going to test it with my DVD remote tonight... If it works I'll probably just keep using the regular creative remote, then see if I can find a discarded onkyo remote, or buy a universal remote and try pluging away with different codes.
              aka Kumaneko
              "Don't make me moderate your ***!"
              Maxima of Doom - project thread - photo gallery
              mp3car system is currently FUBAR and finances do not allow for a correction of that situation
              Real computer hackers use a rotary cutting tool on their motherboard.
                IRMan with a pioneer steering wheel remote.... I was using a home-brew IRMan with a PIC chip I got programmed by a mate (big into the PSX mod scene so he had a programmer and the chips are identical to PSX-One mod chips)...
                but sadly it doesnt work with my new EPIA 800 mobo, since the COM port doesnt put out quite enuff voltage to run the IR sensor.
                So now I use my purchased IRman, ripped apart and mounted with the sensor away from the circuitry.. identical to the one smashr2k is using... oneday I will locate a local supplier of the IR sensors identical to the ones the IRman uses and all should be fine with regards to the home-brew IRman
                Project - GAME OVER :(
                  Just a keypad, using a very big and complex girder file which I made.. .to controll every program I'm using in the car ... GPS, Winamp, AutoPlay, MediaEngine, Games.... and lots more.. (Each program has its own "mode" for the keypad, and girder changes every key function on the keypad, depends on which program that that has the focus...
                  Ill be happy to share the Girder file, since I've noticed ppl are having difficulties with Girder
                  RIchard
                  "If A equals success, then the formula is: A=X+Y+Z. X is work. Y is play. Z is keep your mouth shut."
                  Albert Einstein
                    Spud discovered that the serial port runs 5v rather than 12v on the EPIA 800 - and modified the irman to suit.
                    Maybe that might help?
                    C!
                    http://carpc.riposte.net
                    I reserve all rights in connection to each post I author, without exception.
                      I have a complete set!
                      • Remote control for all the major functions, via an irman that controls an application directly (instead of running through girder)
                      • Fellowes PS2 touchpad mouse in the centre console for mousing duties (rarely used)
                      • USB mini keyboard in the back of the seat-pocket for emergencies (connects to USB hub in the centre console)
                        C!
                        ohhhh really..... do you have a link to that post??? or I might just PM Spud directly....
                        well at the least that supports my theory.... no biggie, im gonna get a few propper IR sensors in a few weeks - no more of the pathetic ones from Jaycar and Dick Smith elecs...
                          I primarly use a Packard Bell remote with girder, but I have a Fellowes (Cirque) touchpad and a wireless Logitech keyboard.
                          Touchpad:
                          IR Reciever:
                          RF Keyboard Reciever:
                          -Nick
                          _____________________________
                          www.mp3vw.com
                            I use touch screen, RF mouse, and IRman remote. I made the buttons big so it's easier to touch the buttons.
                            NEW complete and updated My project with 100+ pics on 7-4-03
                            If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
                              MP3Dub, where is the touchpad in the first picture? Am i just blind? or is it a stealth install? If its actually part of the steering wheel i am very impressed : )
                              Progress here: http://www.siriuscybernetics.net
