USB help please?
  • USB help please?
    My car pc is not picking up on the usb touchscreen or usb gps antenna all the time. I usually put it in hibernation instead of shutting it down, but sometimes I shut it down instead. Anyways, the usb picks up half the time and it doesn't pick up the other half the time. Is there any way to refresh all the usb ports with out restarting or something I can try to make them pick up?
    Are you using a hub?
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
      I'm using a hub on the screen but not the gps and both have the same problem
        Hmm...might want to check your USB drivers...
