UPDATE - Xbox thumbstick media control
  • UPDATE - Xbox thumbstick media control
    UPDATE - see page 2 for attaching additional buttons
    http://www.mp3car.com/vbulletin/inpu...control-2.html
    the xbox controller is a very versatile piece of hardware, it can be configured in just about any way.
    heres the way i configured it:
    1. i removed everything from the controller board.
    2. then soldered an extension wire for the left thumbstick (about 1')
    3. soldered a USB cable instead of the original cable (just match the colors)
    4. then install the xbcd drivers to recognize the controller as a joystick.
    5. and the last stem is a program thats called JOYTOKEY.
    6. bind the thumbstick to send multimedia keyboard signals.
    LEFT-0xB1 (next track)
    RIGHT-0xB0 (previous track)
    UP-0xAF (master volume up) repeat 16 times/sec (steps)
    DOWN-0xAE (master volume down) repeat 16 times/sec (steps)
    Button 9 (thumbstick press) - 0xB3 (play/pause)
    7. then under advanced - set threshold to 50% to make it less sensitive, and send the signals when its moved half way in the assigned directions.
    thats it.
    also this controller can provide much greater functionality. later on im going to bind the toggle fullscreen keys for centrafuse.....
    2007 Toyota Tundra Double Cab SR5
    >"Say what you mean and mean what you say"<
    This looks pretty interesting! Good luck with the future functionality, I will keep my eye on this thread because I feel as though it's something that I can use/integrate into my car.
    Obtain components [-------------------X] 100%
    Obtain touchscreen [-------------------X] 100%
    Configuration [-----------------X--] 90%
    Wiring [------------------X-] 95%
    Install [------------------X-] 95%
    -You're never really done with these projects!
      this is what the final product looks like (o;'
      notice the thumbstick to the left of the monitor.
      all it needs now is a backlight ring...
        okk so i made a few adjustments to Xbox joystick setup.
        the thumbstick next to the monitor operates as a mouse.
        and volume and next/prev tracks thumbstick is right at the fingertips while driving (o;'
          Very nice, great idea i like it.
            Very good hack .
            Is the button as , if i understand, 2 axes and 1 push function ?
              Hello, pardon my English, this is translated by google:
              I built this with a USB joystick like playstation:
              http://www.fuegomp3.com.ar/inicio/in...&limitstart=11
              The configuration is like your analog control, I give you a tip, in Joy2Key you got the ability to create multiple profiles, and assign a button to switch profiles in profile, with this you can use the lever and the button for several more functions.
              http://www.mp3car.com/vbulletin/atta...1&d=1253106040
              I hope you understand what I wrote.
              Greetings,
              Nelson.
              My Site: www.fuegomp3.com.ar
              Renault Fuego 84 Carpc & full worklog
                Originally posted by pierrotm777 View Post
                Very good hack .
                @sergatiuk
                i would like to know the same thing
                CTS 05, Mobile Information Center...
                Atom - 1.8ghz
                2GB Ram
                32GB SSD
                8" TouchScreen
                5.6" Screen (overhead) w/reverse capability
                Finished Project
                Car Hacking
                WorkBlog
                Video
                  Very good hack .
                  yes that is correct, Y - volume, X - next/previous track, push - play/pause
                    thats a good point, one might want to use the same analog stick as a mouse as well and switch the profiles by pushing on the analog stick. and yes that is very easy to achieve in joy2key
                    in my case i just used 2 thumbsticks, but in cars with not much space to mount a second one this would be a great idea, in case you want to use a cursor for web browsing or other external apps in centrafuse or RR
                      Is it a xbox or xbox 360 controler ? Do you have a picture of this controler please .
                        i used the original Xbox controller, i believe the Xbox 360 controller can be used as well, the Playstation controller may also be used for this purpose.
                        technically speaking, any USB joystick or controller will work.
                        the benefit of the game console controllers is the thumbsticks, they are very small and offer many functions.
                          My idea is to use the second stick to make a rotary control like this:
                          Click Here.
                          With the rotary control could move in the menus of the RR.
                          Regards, Nelson.
                            [QUOTE=sergatiuk;1343015]i used the original Xbox controller, i believe the Xbox 360 controller can be used as well, the Playstation controller may also be used for this purpose.
                            I had used my own game pad (Logitech RumblePad) for test with Ride Runner .
                            It is so cool !!!
                              i saw another thread in which they used a PS/2 mouse to get this accomplished... I'm wondering and hoping i can use my existing jog wheel on the steering wheel to do this.
                              Atom - 1.8ghz
                              2GB Ram
                              32GB SSD
                              8" TouchScreen
                              Finished Project
                              Car Hacking
                              WorkBlog
                              Video
